Ridge Vent Choices. - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-26-2011, 12:44 PM   #1
Indentured Servant
ridge vent choices.
I am about to put a ridge vent in my home, pitch is 12 - 12. I will be cutting the vent in and putting the vent in myself. I will have help on the ground, but only me on the roof. I see two types of vents, the roll out ones and the sectional, I think 4 foot long pieces. Which do you think would be easier to do without any rooftop help? Leaning towards the pieces instead of having the roll keep falling as I roll it out.
jackpine is offline   Reply With Quote
Old 07-26-2011, 01:03 PM   #2
AGWhitehouse's Avatar
Totally a means and method question. If you think the 4' sectional will be easier for you then do it. If the roll gives you the warm and fuzzy, then use it. Either product, if the specs are similar, will function the same once installed so it's a matter of how you wish to install it.
If you're worried about it falling you could always unroll it totally and tack the end somewhere down the line of the ridge (not too far that it is stretched to reach the start point).
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 07-26-2011, 01:27 PM   #3
Indentured Servant
Oh and another question, is it common to vent the entire length or just the area above the rafters, leaving the overhangs invented?
Old 07-26-2011, 05:48 PM   #4
I've seen it done either way. The overhangs don't need to have the vent strip.
Old 07-27-2011, 12:10 AM   #5
Thats the way I would do it, with the 4 foot sections, similar to a product such as Shingle Vent II from the Air Vent Corp., and for cosmetic purposes only, I would run the ridge vents from end to end, so that the roof looks like you did not run out of materials.
Ed
Ed the Roofer is offline   Reply With Quote
Old 07-28-2011, 12:09 AM   #6
Registered User
Rewards Points: 4,894
A finer point on some mesh: http://www.inspectapedia.com/interiors/atticcond10.htm
Gary
Gary in WA is online now   Reply With Quote
New Roof marknok Roofing/Siding 4 08-06-2011 12:41 PM
new roof, ridge vent was in est, but not installed... Zel1 Roofing/Siding 29 09-01-2010 05:30 PM
Shingling over ridge vent -details needed jogr Roofing/Siding 4 11-06-2009 06:47 PM
Hip caps to ridge vent KEITHnhia Roofing/Siding 1 07-04-2009 02:17 PM
Ridge Vent on a Shed jokiddjr Roofing/Siding 5 03-14-2008 04:22 PM
