I noticed that in the picture showing the area behind the chimney (up the roof slope), that area is flat all the way down to the chimney. Has there ever been a "cricket" installed there? This would certainly facilitate the water runoff instead of water collecting behind the chimney and possibly rising up over any flashing. Also-I (me) particularly don't like the flashing on the sides of the chimney, there are only a couple of large pieces. I like "step-flashing" which rises with each course of shingles, and the brick has a cut in it for the flashing to fit into. Good Luck, David
The roofer is obviously stumped an unable to find the problem, hence all the exposed roof cement on all those vents and chimney flashing's.
Roof cement is an acceptable material to use but not when it is left exposed like they have done.
I would ask the city for an inspection if I were you.
The county building inspector came out today.
1) He noted the sloped tar all over the place but did not specifically say anything about violating any code
2) Said he could not tell if the ridge vent is installed correctly with out removing it to see underneath
3) Did say the flashing on the corners of the chimney did not look right or suspect??
4) Scratched his head on the dryer vent. Strange vent or something and thought it could be a possible water entry. I still believe it is not the correct vent for a dryer vent.
5) Agreed it did not appear they replace the jacks or the vents when the reroof was done
Apparently they see this type of thing on regular bases. Said at least this company is still in business and has an active license. This roofing company is quite large actually but their home base in another state.
The county inspector is going to call and request the roofer address the issues. He said sometimes when the county contacts them they respond. If they do not respond and correct the issues/leaks, county will report them to the state. I assume this is the state licensing board. BTW, the roofer stated they would do the vent and ridge vent this week. They were a no show again.
What I do not understand is how the county signed off on the permit inspections in the first place?? Can you or another roofer pinpoint the suspect chimney flashing issue in the picture provided?
"4) Scratched his head on the dryer vent. Strange vent or something and thought it could be a possible water entry. I still believe it is not the correct vent for a dryer vent." -------- because it is not. It cannot have screens to trap the lint and cause back pressure causing a motor burnout and fire in your dryer. Or the very least a plugged vent duct that extends drying time. It needs a backdraft damper, also. There may be one under the cap but it soon would fail due to the screens stopping the lint there. Clothes Dryer Connectors flex. [must be metal] max. 8ft. {6ft.} [1501.1,2437.5] {504.3X}
Connector not concealed in construction . . . .[1501.1,2437.5] {504.3.X}
Duct must be smooth metal inside . . . . . . . .[1501.1,2437.5] {504.3}
No screws in airflow . . . . . . . . . . . . . . . . . .[1501.1,2437.3] {504.3.1}
4in. min. duct [elec. = appliance outlet size] [1501.2,2437.5] {908.1}
{14ft. inc. two 90° bends minus 2ft. per add'l. 90°} . . . .[n/a] {504.3.2}
[25ft. minus 22 ft. per 45° bend or 5ft. per 90°] . .[1501.3,2437.5.1] {n/a}
No mixing with or passage through other systems . .[1501.1,2437.3] {504.3.1} End outside in backdraft damper & no screens[1501.1,2437.3] {504.3.1}
When did you last clean your dryer ducting? If it was over six months ago, then do it this weekend! You don't want to be a dryer-fire statistic.
Wash your lint screen of residue from fabric softener sheets that restrict air flow leading to longer drying time.
Roofing cement left exposed to the weather will crack and create little gaps that will hold water and cause increased "speed up" deterioration of the roofing materials immediately surrounding that area.
The chimney flashing's show irregular laps and corner wraps,
plus show a poor slope at the top "rear" which will not allow water to run off properly, the slower water runs on a roof the more damage it will do.
GBR, said it all with the vent cover.
The other box vents have severe denting/bends in the top portion, thus gives you the same poor slope issue as the top side of the chimney.
God Fearing, Husband/Father, US American, Pool Shooting Roofer
You should have a cricket behind that chimney, there is no way for water to shed off the sides, plus he used a vent for the dryer that will collect all of the lint making that a fire hazard. You need a 4" minimal GRV with no screen, but having a damper in it intead. The off ridge vent he used is the style that is not affected by wind driven rain, however it doesn't look to be pitched correctly, resulting in ponding water. Please keep in mind these are all suggestions made from pictures, but I think they would help. Good luck.
Unfortunately I was unable to be present when the inspector came out. I got the information second hand. He did make the comment that he hopes it is not our fault (meaning the inspectors fault). Not sure what that meant unless they are held accountable. And even if they are, what does that mean for the home owner?
1) Dryer Vent used:
When I visited I noticed the dryer was extremely hot and when the door to the dryer was opened, steam came out of the dryer. No air flow out of the dryer vent. I got on the roof to see and notice that this non dryer vent was used. The roofer tried to say if the internal screen was removed (which it is not), that vent can be used. I immediately told my mother not to use the dryer until we get that vent cleaned and that vent cover on the roof replaced. Maybe this is just one of the many items the inspector should have flagged in the inspection process.
2) cricket behind that chimney
How much room is required between the back of the chimney and the ridge to put a cricket? Roofer stated there was not enough room and that was the reason why no cricket was installed. However most of the chimneys I have seen, the flashing extends beyond the sides of the chimney so the water is diverted away from the sides of the chimney. Roofer stated the flashing is good. Looks like he is the only one that thinks so.
3) off ridge vents
Actually, he reused the 20+year old vents. I wonder if the flashing is rusted and has pin whole leaks. Yes, the water gathers on the top of the vents and I wondered if this could cause leaks. I believe the tops are dented in from them reusing them.
The inspector indicated he wanted the inspector, roofer and home owner to meet at the house to discuss the issues. If a miracle happens and the roofer shows, what would a reasonable request be?
Is this reasonable?
1) Replace all vents, jacks and flashing which includes removing/replacing shingles, and inspect/replace rotted decking around chimney. I’m pretty sure this is required to replace the flashing as I believe the sealed the shingles down when the attempted to fix a year or so ago.
2) Remove/replace all shingles from rear of house. Install missing flashing metal between the house and start of the porch and inspect and replace decking if rooted.
3) Repair ceiling damage
Anything else?
The ridge vent, the other vents, the pipes are all installed wrong. I doubt the roof is even nailed correctly and probably, you will find nails in or near the butt joints. Never saw so much cement on a functional shingle roof before either.
Here's the RV detail. http://www.albertsroofing.com/Ridge%20Vent%20Detail.htm
I replaced the shingles on my roof last year and it was my first DIY project. I removed the plastics ridge vent because the ridge is perpendicular to the prevailing west wind from the jet-stream. I installed a box-vent on the west facing roof and gable vents on east and north. I didn't have compressor and coil nailer, just used a hammer. It was hard work for 29 squares roof. I only removed a small area of old shingles which I could replace in one day. Some areas were done in the spring and others in the fall; I didn't want to work in hot summer days. The new roof has been tested for one winter and one summer and so far so good (no leaks). I used Owens Corning Oakridge shingles manufactured in Minneapolis (paid $10.99 per bundle). I followed the instructions printed on the package; the woven valley was learned from Internet.
I was at the house on a visit and did some more investigation. The county inspector to date has had no luck with the roofer. This company is supposedly fairly large and “does” business in states: FL, TX, OK and a few others. I’m no roofer and I can see issues and have no idea why they will not fix the leaks other than they do not care about reputation and the work the have done. I will be turning them into the Florida Department of Business and Professional Regulation (license board) and the Florida Attorney General’s office. I don’t think this will help get the roof repaired, but hopefully the license board will fine and suspend their license. The county inspector stated they will turn them in if they do not respond in a timely manner as well. I would like to do some repairs, but not sure how to proceed. The paper work states if there is any work done to the roof it voids the their useless warranty.
Here is what I found when I went back. A closer look at the ridge vent (I’m not sure it is leaking at the RV, but something sure looks odd. Kinda like a snake):
These so called roofers that came up from one of their south FL work sites piled on more tar which cracked:
These so called roofers stated they could not see where flashing could be leaking on chimney. It looks like a couple of patch jobs on top of each other to me. I’m not sure what is under the outer layer, but the metal does not wrap around the lower edge and they cut it short exposing the under layer. Sure looks like a leak prospect to me (In the middle of the picture you can see the cut of flashing at an angle and edge exposed):
This is a closer picture of one of the top edges of the chimney (that nail look suspicious and not sure what is under the goop) :
Here is a picture from attic of the dryer vent. Looks like it is leaking.
Odd thing is water must be running a long ways from this entry point.
Here is a roof jack just above the dryer vent. Looks like a possible stain from leak:
Damage done on inside:
Since the last visit, the popcorn ceiling has fallen off on the patch to right.
Roofs last along time, so it's entirely possible you have owned a home without ever having to pick replacement shingles. Or, it has been such a long time there are new products on the market from which to choose. Pick replacement roof shingles by... Read More »
At some point, you may need to replace the flashing around the vents in your roof. If you aren't afraid of heights, you can replace the flashing yourself. Make sure you don't fall. Also, wear gloves to protect your hands from the sharp edges of the vent... Read More »
Ice fishing is a popular pastime in the northern states where the lakes and rivers freeze. The ice fishing houses range in sophistication from a little pup tent to a fully built, functioning home. There are several ways to heat the ice fishing house... Read More »
Tin roofs have been around for centuries. The tin roof at Monticello, Jefferson's home, is still in good condition, despite being the one originally placed on the house when it was first built in the 1800s. Occasionally, it is necessary to pop one or... Read More »
A clothes dryer doesn't need a lot of maintenance, but what it does need is important if you don't want to come home to a load of burnt laundry--or a burnt house. Following are steps for making sure to maintain your clothes dryer, keeping it free of lint... Read More »
