Ridge Vent, Box Vents Or None... - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-28-2012, 05:03 PM   #1
ridge vent, box vents or none...
I have 1300 sq ft of attic space and a low pitch roof (not sure of the ratio). There are soffit vents along both sides of the house plus two gable vents. One roofer says I don't need additional ventilation the other says I need a ridge vent. All thoughts would be appreciated.
Thanks,
twhlady
twhlady is offline   Reply With Quote
Old 03-28-2012, 05:06 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 878
Ridge venting would be ideal if you have proper and unobstructed soffits.
Soffit + Ridge venting is a relatively ideal scenario as long as the design of the home/attic/roofline allow for it.
The Following User Says Thank You to Windows on Wash For This Useful Post:
twhlady (03-31-2012)
Old 03-30-2012, 11:46 PM   #3
Ridge vents, box vents or none...
Thanks for your input. I have just one other question. Is there any truth to what I read that says, if you have gable vents don't use a ridge vent because it destroys the whole ventilation purpose?
Old 03-31-2012, 12:39 AM   #4
RFN-4A-LVN
Roofmaster417's Avatar
Agreed
Roofmaster417 is offline   Reply With Quote
Old 03-31-2012, 12:42 AM   #5
RFN-4A-LVN
Not necessarily.Depends on the size of the gable vent.
Old 03-31-2012, 12:27 PM   #6
Thank you roofmaster 417, I feel better about making my decision. This is a great site for people like myself that know nothing about roofing and have no one to ask. Thanks again!
Old 03-31-2012, 02:16 PM   #7
Registered User
Rewards Points: 4,912
1. Before giving you advice, we need to know your location.....
Wet, cold coastal areas may not need vents:http://www.fpl.fs.fed.us/documnts/pdf1999/tenwo99a.pdf
Hot, humid climates do better with conditioned attics rather than vented ones: http://www.joelstiburek.com/topten/south.htm
Air sealing the attic is as/more important than ventilation: http://www.jlconline.com/cgi-local/v...170a32100a05c7
2. Is your insulation per minimum code for your area?
3. Have you had ice-dams to warrant more ventilation?
4. Is there mold/mildew or wetness showing in the attic requiring installing more ventilation?
5. Is any HVAC ducting or units in the attic?
6. Has it ever been air-sealed?
Gary
Old 03-31-2012, 07:08 PM   #8
Haverhill Trade 1965
All the information I have says if you have soffit vents, you should have ridge vents, 1st choice because no matter which direction the wind is from, one side is under pressure, and because it flows through the vent, it creates a siphoning effect out the exhausting side. Louvers and soffit are marginal, they don't exhaust the air above themselves, and depending on wind direction one is almost always pressurized and one exhausting. Ridge vent and louver, the ridge is going to draw air from louvers before soffits. Added to the rest of the info you got here you should be able to make a better decision.
Duckweather is offline   Reply With Quote
The Following User Says Thank You to Duckweather For This Useful Post:
Old 03-31-2012, 09:40 PM   #9
ridge vents, box vents or none...
Wow GBR in WA you've given me more to think about! I live in Arkansas. How many people really give this much thought to putting on a new roof??? Lots of homework to do now! Thanks
Old 04-01-2012, 10:57 AM   #10
Rewards Points: 878
Not really.
If you have existing soffit vents, you need to install a ridge vent and balance the system.
Despite Gary's links, you are not going to convert what is a vented attic into and unvented/conditioned one.
Old 04-01-2012, 11:55 AM   #11
ridge vents, box vents or none....
Thanks Windows on Wash! My next step, even though I have soffit vents, is to see if they are obstructed.
Old 04-03-2012, 09:32 PM   #12
Registered User
You are welcome, glad we could help! If one doesn't learn something everyday, they are not trying..... those should take you in to next week. LOL.
Gary
New Roof marknok Roofing/Siding 4 08-06-2011 12:41 PM
proper intake vents for ridge vent?? arty007 Roofing/Siding 14 07-31-2010 01:28 PM
Ridge vents? klab Roofing/Siding 7 06-28-2010 03:05 PM
Shingling over ridge vent -details needed jogr Roofing/Siding 4 11-06-2009 06:47 PM
sofit vents + gable end vents no ridge vent mattg1970 Roofing/Siding 5 10-18-2007 10:47 AM
