Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 07-14-2008, 09:00 AM   #1
Ridge-Vent or Attic Fan?
Loking for recommendations: We are getting a new roof and are considering either getting a ridge vent or an attic fan. Any suggestions on which is the better option to go with and why? Thanks...
ray maurone is offline   Reply With Quote
Old 07-14-2008, 07:43 PM   #2
My personal preference is the ridge and soffit vent( no electricity) if you are concerned about air flow adding gable vents , or a single solar fan will give you more then enough air
geo fan is offline   Reply With Quote
Old 07-14-2008, 08:47 PM   #3
Check out airvent.com- it will show you that you should never install ridge vents with gable vents- you'll short circuit your home' s ventilation system. With an attic fan gable vents work even better by drawing the cold air (high pressure area) up through your soffit vents and then into your attic (low pressure) and out through your gable vents.
malibuvan is offline   Reply With Quote
HOT attic, ridge vent/soffit vent questions gone_fishing Roofing 36 07-14-2008 10:26 PM
Ridge Vent > Gable Vent jelly Roofing 10 06-09-2008 08:30 AM
Ridge Vent on a Shed jokiddjr Roofing 5 03-14-2008 04:22 PM
low-slope roof and leaky ridge vent downers Roofing 15 02-22-2008 12:35 AM
Useless Ridge Vent? itwerx2 Roofing 22 10-22-2007 10:57 PM
