Ridge Vent - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-29-2010, 03:16 PM   #1
ridge vent
We have an older home, no air conditioner,, live in the deep south. we have soffit vents and gable vents at each end of attic. we were advised to get ridge vent and it would make our home cooler. is this true. no need to spend if it does'nt make a difference.
brunoangel is offline   Reply With Quote
Old 07-29-2010, 03:20 PM   #2
Electrician
Proby's Avatar
It might. If your attic is sealed off from your house and you have a good layer of insulation between them, the temperature of the attic will effect the temperature in your house less.
Deep south, no A.C.?
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
The Following User Says Thank You to Proby For This Useful Post:
brunoangel (07-29-2010)
Old 07-29-2010, 03:27 PM   #3
yeah, what was I thinking... oh yeah the price was awesome!! But yeah, seriously, whew...(slowly melting...pound by pound!)
Old 07-29-2010, 07:57 PM   #4
Rewards Points: 1,088
You could also consider closing off the gable vents and installing a powered or solar attic fan instead of the ridge vent. Just make sure your soffit vents are appropriately sized. The power attic vent in this setup will move the hot air out faster. Also, adding more insulation will help.
handy man88 is offline   Reply With Quote
Old 07-30-2010, 07:42 PM   #5
Registered User
Rewards Points: 5,516
http://www.ronhungarter.com/ventilation_repairs.html
http://www.advancedenergy.org/buildi...%20Studies.pdf
Be safe, Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
seeyou (07-30-2010)
new roof, ridge vent was in est, but not installed... Zel1 Roofing/Siding 29 09-01-2010 04:30 PM
Shingling over ridge vent -details needed jogr Roofing/Siding 4 11-06-2009 05:47 PM
Hip caps to ridge vent KEITHnhia Roofing/Siding 1 07-04-2009 01:17 PM
Ridge Vent on a Shed jokiddjr Roofing/Siding 5 03-14-2008 03:22 PM
low-slope roof and leaky ridge vent downers Roofing/Siding 15 02-21-2008 11:35 PM
