Ridge Vent - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-01-2009, 04:59 PM   #1
ridge vent
I have a cold roof that was put on last year over the existing roof. It has a ridge vent and soffit vents. The original roof also had a ridge vent that is now closed off. Should there be an opening into the attic or should the air space all be above the original roof?
Any advice would be appreciated.
roz lowen is offline   Reply With Quote
Old 05-02-2009, 04:45 AM   #2
You built a new roof on top of the existing roof, with a new air cavity, correct?
If so, then yes, the interior attic compartment should disperse the contained moisture content to the out side environment.
Ed
Ed the Roofer is offline   Reply With Quote
Tags
cold roof , ridge vent
new roof, ridge vent was in est, but not installed... Zel1 Roofing/Siding 29 09-01-2010 05:30 PM
Ridge Vent > Gable Vent jelly Roofing/Siding 10 06-09-2008 08:30 AM
Ridge Vent on a Shed jokiddjr Roofing/Siding 5 03-14-2008 04:22 PM
low-slope roof and leaky ridge vent downers Roofing/Siding 15 02-22-2008 12:35 AM
Useless Ridge Vent? itwerx2 Roofing/Siding 22 10-22-2007 10:57 PM
