Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 09-07-2008, 10:50 AM   #1
ridge vent
I have a cape with a shed dormar on the back. The pitch of the dormar is about 3/12. The front is about a 5/12. Is it going to be a problem putting on a ridge vent with the dormar being a low pitch as far as leakage? I live in northeast with snow that sits on the roof.
hitmehhh is offline   Reply With Quote
Old 09-07-2008, 07:34 PM   #2
Super Moderator
ridge vent
I do it all the time under the same weather conditions, but in the Chicago Area.
I would Only use the Shingle Vent II or Cobra Snow Country Ridge Vent Products and I also install a J-Channel in the center of the vent over the decking on the low slope 3/12 roof, without cutting out the wood on that side of the roof peak and cut an extra 1/2" to 1" on the 12/12 side, for that area only. The rest of the 12/12 equal on both opposing sides get done the normal way.
The longer leg of the J-Channel gets installed so that the top course of shingles, which get cut horizontally, slides Under the top course shingle edge. I also make sure that there is a heavy bead of Geocel or NP-1 sealant under the External Baffle portion of the plastic ridge vent product on that side, especially when being installed over an architectural shingle which has a few up and down tab configurations.
Ed
Ed the Roofer is offline   Reply With Quote
More On This Topic
Hi! This is Jon on behalf of Expert Village. In this video clip, we will checking the roof for loose or missing shingles. To check for any loose or missing shingle, you just want to take a close look at your roof. If there are any areas that might look... Read More »
We are going to talk a little bit about our waste lines and our vent lines right now. The waste line being when you turn the sink on and the water that falls into the sink, where does it go, well it goes right down into this pipe here, travels down the... Read More »
Hi, this is Jon on behalf of Expert Village. In this video clip we'll be calculating shingles. To calculate the number of bundles of shingles for a basic gable roof first we need to measure the length and the width of the rectangular areas that is adding... Read More »
Roofs last along time, so it's entirely possible you have owned a home without ever having to pick replacement shingles. Or, it has been such a long time there are new products on the market from which to choose. Pick replacement roof shingles by... Read More »
At some point, you may need to replace the flashing around the vents in your roof. If you aren't afraid of heights, you can replace the flashing yourself. Make sure you don't fall. Also, wear gloves to protect your hands from the sharp edges of the vent... Read More »
Ridge Vent > Gable Vent jelly Roofing 10 06-09-2008 08:30 AM
Ridge Vent on a Shed jokiddjr Roofing 5 03-14-2008 04:22 PM
low-slope roof and leaky ridge vent downers Roofing 15 02-22-2008 12:35 AM
Useless Ridge Vent? itwerx2 Roofing 22 10-22-2007 10:57 PM
Ridge Vent - Low-pitched roof? brianp Roofing 2 05-08-2006 09:32 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
