Ridge Vent - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-07-2012, 03:30 PM   #1
Ridge vent
Are you suppose to apply cobra ridge vent on a 12 12 pitch
WILLIAM PERRINE is offline   Reply With Quote
Old 05-07-2012, 03:33 PM   #2
Rewards Points: 12,790
Why did you post in the appliance area, instead of the roofing area.
Any pitched roof needs a ridge vent.
Old 05-08-2012, 12:39 AM   #3
Registered User
Rewards Points: 4,888
Welcome to the forums! You'll be scooting around in the different rooms in no time....
Would not be my first choice:
http://www.oikos.com/esb/30/atticvent.html
http://www.buildsite.com/dbderived/a...rived20936.pdf
http://www.inspectapedia.com/interiors/atticcond10.htm
Gary
Old 05-08-2012, 01:28 AM   #4
Opps I missed the Cobra part.
All my roofing supplyers have stoped selling it.
It does not vent enough air and is a royal pain to install and not have it look like a snake eatting a rat.
This works better.
http://images.search.yahoo.com/image...mb=cpCLpHoH11V
Windows on Wash (05-08-2012)
Old 05-08-2012, 08:17 AM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 820
+1
We never use the roll out cobra vent any more. It is cheap and can easily be installed improperly and create major headaches.
Old 05-08-2012, 09:12 AM   #6
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
That's a pretty broad, sweeping statement there.
seeyou is offline   Reply With Quote
Old 05-08-2012, 09:39 AM   #7
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Pitched roofs with spray foam insulation installed in the rafters, don't need a ridge vent in my region.
- Build Well -
Old 05-08-2012, 10:47 AM   #8
Rewards Points: 820
+1
Hot roof designs (whether spray foam or otherwise) do not require roof ventilation if they have enough R-Value and air tightness in the roof.
Ridge vent on 2:12 slope cathedral roof DaveM75 Roofing/Siding 5 09-28-2016 04:47 PM
Is it common for roofers to NOT slice underlayment on a ridge vent before installing? jcarlan Roofing/Siding 29 01-05-2012 04:26 PM
Roof ventilaton - hip roof (ridge vent, fan, power vent ?) rkpatt Building & Construction 2 06-02-2011 05:21 PM
Ridge vent shingling..How to do it properly? J S Machine Roofing/Siding 5 01-18-2011 12:58 PM
Attic Ventilation Question handy man88 Roofing/Siding 10 02-12-2010 11:50 PM
