Ridge Vent - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-04-2011, 11:03 AM   #1
Ridge vent
In a recent wind storm my shingles on my ridge vent stood up. Should they be replaced or just sealed down.
marmac is offline   Reply With Quote
Old 04-04-2011, 11:10 AM   #2
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
They should be able to just be pushed back into place.
I would seal them down as you do it. (on a nice warm day so they flex )
Look for rips or any damage in them.
Was this a prevailing wind or a fluke wind from another direction?
I ask because most caps are installed with the open side away from the prevailing wind so water has less of a chance of penetrating and your caps don't get blown off.
tcleve4911 is offline   Reply With Quote
Old 04-04-2011, 11:10 AM   #3
Stay-at-home GC
Did they crack when they bent? Were they sealed down well originally? They should be installed with the nailed end "upwind" of the prevailing wind direction (Site specific)
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Old 04-04-2011, 11:23 AM   #4
Ridge vent
They were installed facing the south. Sounds like a mistake. Should I have it redone ?
Old 04-04-2011, 11:40 AM   #5
Stay-at-home GC
Not necessarily incorrect. Some sites have an obvious prevailing wind direction. Some homes are oriented 'cross ways' to the wind. In that case it would be a coin toss.
Old 04-04-2011, 12:31 PM   #6
Thanks for all the help, I think I will try sealing them back done.
Old 08-20-2012, 09:29 PM   #7
Do ridge vents last the life of the roof?
B. Smith is offline   Reply With Quote
Old 08-21-2012, 07:46 AM   #8
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,798
Properly installed, yes.
Do they cheaper aluminum units blow off a bunch, yes.
new roof, ridge vent was in est, but not installed... Zel1 Roofing/Siding 29 09-01-2010 05:30 PM
Shingling over ridge vent -details needed jogr Roofing/Siding 4 11-06-2009 06:47 PM
Hip caps to ridge vent KEITHnhia Roofing/Siding 1 07-04-2009 02:17 PM
Ridge Vent on a Shed jokiddjr Roofing/Siding 5 03-14-2008 04:22 PM
low-slope roof and leaky ridge vent downers Roofing/Siding 15 02-22-2008 12:35 AM
