Ridge Shingles Question? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-20-2010, 07:17 PM   #16
kwikfishron's Avatar
Rewards Points: 176
Is that three tab?
What kind of crazy pattern it that?
What’s with all of the stacked seams?
It's making my eyes hurt.
I must need new glasses.
kwikfishron is offline   Reply With Quote
Old 07-20-2010, 09:45 PM   #17
MJW
GAF Timberlines.
MJW is offline   Reply With Quote
Old 07-21-2010, 09:00 AM   #18
GAF Timbertex.
With the high profile of the Timbertex, it will look *almost* like that. It should be sitting down a little lower.
There are three layers to the Timbertex. Two layers of what you see exposed and another layer about 3 inches that is not exposed. That is why that one side is sitting up higher than the other. They did not remove the "nailing" layer from the course under it.
BamBamm5144 is offline   Reply With Quote
Old 07-21-2010, 12:19 PM   #19
Rewards Points: 12
That's pretty much SOP for roofers. I just installed a ridge vent and had to do the same thing where it butted up to the frame/facia. I actually ran it all the way, then cut the last cap in half to cover the very end. As long as you put a good silicone product or roof tar on the nails, they won't leak. Avoid using caulk unless it's got silicone (gets brittle).
igneous1 is offline   Reply With Quote
Pitch and ridge vents igneous1 Roofing/Siding 3 05-10-2010 05:07 PM
Ridge vent question turbomangt Roofing/Siding 1 05-10-2010 05:06 PM
A few roof questions before I begin... chrisexv6 Roofing/Siding 6 05-02-2010 07:16 AM
Ridge and hip shingles Axe McGee Building & Construction 2 04-29-2010 09:09 PM
First roof ... am at the hips and ridge KEITHnhia Roofing/Siding 4 06-23-2009 12:26 PM
