Ridge Cap Shingle Installation Question - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-06-2013, 04:33 AM   #1
Are ridge cap shingles supposed to be installed across the entire length of the roof?
My contractor started them approximately a foot from the edges and they insist that's the way it's supposed to be. I looked at GAF's website and it looks like all of their pictures show the ridge caps from edge to edge.
AdviceWanted is offline   Reply With Quote
Old 06-06-2013, 05:18 AM   #2
747
registered
747's Avatar
Rewards Points: 534
Mine go all the way to the edge. Never seen it done like this before. Is it possible he ran out?
747 is offline   Reply With Quote
Old 06-06-2013, 06:44 AM   #3
Rewards Points: 13,250
I'd your looking and talking about ridge vents not ridge cap shingles.
Two differant things.
If it was cap shingles that were left short there would be a hole on the top of the roof.
Both ways will work, the caps are 4" long and are hard to cut so I just let them end where they will come out even on both ends using full pieces.
Old 06-06-2013, 07:45 AM   #4
Sorry, if I used the wrong wording. This is what I saw being done: they cut out the hole for the venting (not sure how long it was), then I saw a long piece of a black wire mesh, almost like a scouring pad, then they put the regular shingles over everything, then the half-piece of shingles which I thought were called ridge cap shingles on top. Those half-pieces of shingles that wrap over the ridge are the ones that stop about a foot from the edges.
I'm wondering if they ran short and if so, if I should insist they order more and finish the job the way it should be.
Old 06-06-2013, 08:10 AM   #5
#1 No way would I have used that style vent.
All my local shingle supplys and even the box stores in my area stopped selling it because just does not give enough venting, and done wrong it looks like a snake eatting a rat.
Cap shingles should have covered every inch of the vent!!!
Got a picture?
The Following 2 Users Say Thank You to joecaption For This Useful Post:
frankm1960 (06-12-2013), Windows on Wash (06-06-2013)
Old 06-06-2013, 11:39 AM   #6
Roofmaster
Rewards Points: 2,172
All my local shingle supplys and even the box stores in my area stopped selling it because just does not give enough venting, and done wrong it looks like a snake eating a rat.
Got a picture?
Another classic from a classic! Joes right on all counts, except that its a mongoose. That ridge vent don,t do squat except leak in a blowing rain. (Why do you think its named after a snake indigenous to Thailand?)
Old 06-06-2013, 09:51 PM   #7
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,770
Snake eating a rat....that is about the best description I have ever heard.
Must catalog for future reference.
Old 06-07-2013, 03:47 PM   #8
He said the ridge cap shingles were installed along the entire length of the roof, but it looks flatter near the last approximately foot near the edges because the venting doesn't go all the way to the end. He agreed to stuff some venting under those areas to make it look more even.
Does this sound right?
Old 06-07-2013, 03:58 PM   #9
Rewards Points: 628
Sounds pretty normal, ridge vent usually stops where the house stops and the overhang starts, but can be run to the edges for aesthetics.
PatChap is offline   Reply With Quote
Old 06-07-2013, 04:09 PM   #10
With a picture we would know what your talking about.
He may have just layed the shingles over the ends and continued on to the ends of the roof instead of stopping on top of the vent. Which would look odd from the ground but should be fine.
https://roofing.owenscorning.com/doc...-rigidroll.pdf
Old 06-07-2013, 06:01 PM   #11
Here's a close-up picture of the roof. The pink dots show where the venting stops. I don't like the way it's raised along the peak and then tapers lower towards the ends. Most houses around here have the same thickness from end to end.
(we're getting new gutters tomorrow, so don't pay attention to the gutter that is pulled away from the house over the window)
Also, should the copper be showing in the front of the skylight?
Old 06-07-2013, 06:06 PM   #12
Looks ok to be.
Yes that copper needs to be on top of the shingles, not under them at the bottom of the sky lights.
Old 06-07-2013, 06:35 PM   #13
I believe the copper came attached to the skylight. I saw "copper" checked off on the box it came in.
Old 06-07-2013, 07:05 PM   #14
Roofmaster
Just have them run the ridge vent to the gable ends. The deck wont be cut, so it will not function, but it looks much better. The copper will turn brown in a while.
Old 06-08-2013, 07:19 AM   #15
Pipe collar flange is not my favorite type of install either by burying the bottom behind the shingles on the sides.
Whats up with the drip edge on the left side?
Cap shingle installation over ridge vent spcrooks Roofing/Siding 3 06-28-2011 07:58 AM
ridge shingle vent for shed amakarevic Roofing/Siding 1 03-03-2011 11:41 AM
Ridge shingles question? dbell Roofing/Siding 18 07-21-2010 12:19 PM
Shingle Installation with F5S Standard Drip Edge ShortEdged Roofing/Siding 32 02-15-2008 03:10 PM
How much should ridge cap cover the shingle Malcolm Roofing/Siding 4 01-09-2008 02:19 AM
