Ridge Cap Question Using GAF Ridglass - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-22-2012, 05:46 PM   #1
Rewards Points: 12
Ridge Cap Question using GAF Ridglass
I just finished shingling a roof for a shed. I am installing GAF Ridglass cap shingles (Z-tab?) over a Trimline ridge vent. Once I run the cap course, how do I install the final end cap shingle (prevailing wind side)? Nothing in the instructions tells me how to do this and I can't find anything on the internet. Thanks, in advance.
MrUnderhill is offline   Reply With Quote
Old 10-22-2012, 06:15 PM   #2
Rewards Points: 13,296
Cut a cap so only the bottom part is left and use 2, 3" roofing on each side. Cover the nails with silicone or roof caulking.
MrUnderhill (10-23-2012)
Old 10-23-2012, 02:18 AM   #3
Rewards Points: 12
Joe,
Sorry about the question, but I'm an idiot. I'm guessing you mean cut off the end of the shingle that would normally be exposed and then just nail that flush at the end of the roof? Is that correct? Thanks, again.
Old 10-23-2012, 09:11 AM   #4
Rewards Points: 83
You've already brought the caps from one end of the ridge to the other end, stopping about 2 feet from the end of ridge.
Cut off the exposed part, and install THE OTHER piece (I call it a Starter Cap) at the end of the roof. Then install a full cap on that one. Now you should have 2 caps facing opposite directions right? Now you take that exposed piece you cut off and install it over those two caps.
bcdemon is offline   Reply With Quote
The Following User Says Thank You to bcdemon For This Useful Post:
Old 10-23-2012, 09:22 AM   #5
You are correct Mr Underhill.
Old 10-23-2012, 12:25 PM   #6
Rewards Points: 12
Thanks guys...very helpful.
Ridge Vent Installed - what to do about soffits nickc3 Roofing/Siding 3 07-02-2012 05:26 AM
Yet another ridge vent question. ECB ESQ Roofing/Siding 5 05-31-2012 11:00 PM
Pitch and ridge vents igneous1 Roofing/Siding 3 05-10-2010 05:07 PM
Ridge vent question turbomangt Roofing/Siding 1 05-10-2010 05:06 PM
Hip caps to ridge vent KEITHnhia Roofing/Siding 1 07-04-2009 02:17 PM
