Retrofitting Gable End Drip Rail - Roofing/Siding - DIY Home Improvement | DIYChatroom
Like Tree3Likes
  • 2 Post By PatChap
  • 1 Post By ChuckF.
Old 02-02-2017, 10:16 AM   #1
Rewards Points: 44
Retrofitting gable end drip rail
The carpenter that built my house used a 1x2 finger jointed wood strip across the top of my Hardie board fascia. Then, it was painted poorly. Within a few months, mold/mildew was bleeding though. After much research, I decided to just remove it and replace it with a wide drip rail that will cover where the wood strip was.
My question is what can I used to attach the drip rail? I know the absolute best way to do it is to nail it from the top under the asphalt shingles, buts going to be a lot of work. I have 6 gables and over 300 lf to do. I was hoping I could use constructive adhesive, butyl tale, nails, screws, or some other product to attach it on the face.
In my research, I came across some other profiles that were made to simply attach from the face, but it wasn't wide enough for my application. That stuff would have to be attached from the face, but it didn't say how.
Any ideas, suggestions? If it helps, I live in the SE where it gets as cold as 20 F and as hot as 100 F.
apewrangler is offline   Reply With Quote
Old 02-02-2017, 07:03 PM   #2
Rewards Points: 634
Thumbs up
Re: Retrofitting gable end drip rail
Your gonna need to pull nails to get it under the shingles. Likely a lot of nails.
I would be installing 1x2 pvc instead
joecaption and craig11152 like this.
PatChap is offline   Reply With Quote
Old 02-02-2017, 08:52 PM   #3
Rewards Points: 160
Ditto what PatChap said. If the drip rail isn't under the shingles then it doesn't give you the protection of a drip rail. Your shingle overhang should already be an inch or so, without the 1x2 there, your overhang becomes extreme.
craig11152 likes this.
ChuckF. is offline   Reply With Quote
Old 02-03-2017, 11:46 AM   #4
craig11152's Avatar
Rewards Points: 152
I agree 100% with the others.
To do a drip edge right would require pulling a lot of nails...here is some math
300 feet x 12 inches to a foot= 3600 inches
3600 inches 5.5 inches per metric course=about 654 nails +/-
seems like a pvc replacement is a no brainer
Don't look at me. I didn't vote for either one of them.
craig11152 is offline   Reply With Quote
drip edge to seperate gable color begal Roofing/Siding 1 05-26-2015 03:52 PM
Drip edge / rail solution for flat concrete deck jjnero Roofing/Siding 1 07-19-2012 05:02 PM
**PICS *** How should I fix this balcony drip rail? noone Roofing/Siding 17 06-22-2011 08:22 PM
How to protect gable end barge board without drip cap? luvdairish Building & Construction 4 09-19-2010 09:52 AM
Drip Cap or Drip Rail joe3534 Roofing/Siding 7 09-18-2007 04:38 PM
