Retrofit Flashing On Rock Chimney - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-14-2009, 03:25 PM   #1
Retrofit flashing on rock chimney
Oh man...I'm not sure where to go with this...first objective was to keep squirrels out of my attic. Now in addition to that, I want to keep water out of my attic.
I have an irregular rock chimney butted up to the plywood siding, under an overhang.
I'd like advice on sealing the gap you can see in the pictures.
It looks to me, buy the flashing on the inside of the bottom picture, that I'm above the original roof line, and that whoever added a second story didn't tie the flashing into the chimney correctly.
It's been suggested that I use hardware cloth combined with expanding foam insulation to fill the space, which would keep the squirrels out, but I'm not sure about the water.
BTW, I've read that typically you cut a channel in the side of the rock in which to embed another flashing run, but as you can see by the irregularity of the rock surface, and by the ease (lack thereof) entry, I can't really get a grinder or saw in there.
Thanks!
dahirolla is offline   Reply With Quote
Old 11-14-2009, 06:42 PM   #2
Remodeling Contractor
I would use a 14" diamond saw to cut a groove in the stone. (we do this all the time) It will cut like butter. Sealing with flashing is the only solution. Grout the slot in the stone after attaching the new flashing. Be sure to overlap over the lower existing flashing. Fill the void with spray foam to insulate and provide a air and vapor barrier.
Old 11-20-2009, 11:15 AM   #3
Angle grinder with a diamond blade is what roofers use. You only need a small slit for a reglate. 14 inch saw is to big to use for this.
harby is offline   Reply With Quote
Old 11-20-2009, 01:15 PM   #4
under normal circumstances you are correct, but these stones are too big and you need the bigger blade
Old 11-20-2009, 01:43 PM   #5
Really, I am not refering to a little dinky 4 incher, a 9 inch angle grinder would be fine for this. Your not cutting the chimney in half!
Chimney peak flashing richbl Roofing/Siding 5 09-29-2009 05:23 PM
Need roofing tips! dc4nomore Roofing/Siding 114 07-03-2009 07:01 AM
Chimney Flashing mfitzsimons Roofing/Siding 4 04-20-2009 10:00 PM
Which flashing tape for Chimney flashing? gante Building & Construction 9 03-19-2009 10:27 AM
Looking for Chimney Flashing Kit. Prefabricated? gante Roofing/Siding 11 02-27-2009 09:11 AM
