Reroofing Over Low Sloped Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-29-2011, 03:55 PM   #1
Reroofing over low sloped roof
I have a sloped roof with two layers of 90# . A roofer wants to place a 4-ply torchdown over top and install breather vents near top of roof. The last layer of 90# is over 15 yrs. old and has started to leak. I guess I did a poor install when I did the roof.
Thank You for and replies.
Ed
drawde is offline   Reply With Quote
Old 03-29-2011, 03:57 PM   #2
Low Slope Roofing
Rewards Points: 114
Ed
Post some pic's! did they spec any coverboard? What is the roof over? Me I would remove it and possably install soemthing besides a torchdown.
1985gt is offline   Reply With Quote
Old 03-29-2011, 04:45 PM   #3
Thanks for reply. They want to apply the torchdown over top of the old roofing. Sorry that I can not post pictures. I am sure the roof is alligatored due to its age. They did not say anything about a coverboard.
Old 03-29-2011, 10:19 PM   #4
RFN-4A-LVN
Roofmaster417's Avatar
IMO thats a pretty dangerous situation.I would ask for a detailed description of his project procedure.I would do this prior to job commencement.
If not have the # to the fire department handy.IMO
Roofmaster417 is offline   Reply With Quote
Old 03-29-2011, 11:07 PM   #5
Commercial Flat Roofing
4 ply torchdown?
over the top?
Breather Vents?
911 it's easier to remember.
Talos4 is offline   Reply With Quote
The Following User Says Thank You to Talos4 For This Useful Post:
Roofmaster417 (03-30-2011)
Old 03-29-2011, 11:22 PM   #6
Yeah what is a 4ply torch down??? Tear it off check the decking insulate and single ply
Don Smith is offline   Reply With Quote
The Following User Says Thank You to Don Smith For This Useful Post:
Old 03-30-2011, 01:32 PM   #7
Low Slope Roofing
Rewards Points: 114
3 base plys and a cap sheet? Thats alot of torching. Even if you nailed a base. I would really get a detailed proposal on this.
Old 03-30-2011, 02:32 PM   #8
Torch 3 base plys and a cap sheet. Over two 90# that are on it already on it. Holly **** I feel sorry for who ever tears that off
Old 03-30-2011, 02:45 PM   #9
Low Slope Roofing
Rewards Points: 114
I agree. Best to just tear it off and single ply it.
The Following User Says Thank You to 1985gt For This Useful Post:
Old 03-30-2011, 04:26 PM   #10
Thanks for replies. I will go with a .060 rubber roof by a different contractor.
The Following User Says Thank You to drawde For This Useful Post:
Old 03-30-2011, 10:35 PM   #11
Low Slope Roofing
Rewards Points: 114
and tear off the old I hope!
Old 03-31-2011, 10:19 AM   #12
i own a roofing company beenin construction for over 32 yrs. !tear it off check the decking no need to add more weight to a problem area .there's products made bt certainteed called flintastic perfect for the job.remember this protects the inside of your dwelling.id get a second opinion never good to go over any roofing.cowards way out lmao.
ksjbuilders is offline   Reply With Quote
Old 03-31-2011, 10:27 AM   #13
[quote=drawde;619373]I have a sloped roof with two layers of 90# . A roofer wants to place a 4-ply torchdown over top and install breather vents near top of roof. The last layer of 90# is over 15 yrs. old and has started to leak. I guess I did a poor install when I did the roof.
call someone else tear it off please .way too much weight with all that crap on it.
Insulate sloped roof with dense-packed cellulose fabio Roofing/Siding 2 02-24-2011 11:21 PM
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 01:35 AM
Strange Winter Roof Leak Dragon Roofing/Siding 16 10-09-2009 07:06 PM
sloped roof, tight spot to work on. DIYGST Electrical 8 01-05-2009 08:28 PM
Addition and Roof Replacement lebeld Roofing/Siding 4 01-04-2009 07:11 PM
