Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 04-24-2009, 11:06 AM   #1
Replacing wood on 24" center trusses
Trusses 24" on center and builder used 3/8" plywood. Plywood is now delaminating and soft in spots. Would like to rip off all of the wood and use 1/2 or 5/8". Just not sure that the weight would be too much? Also, half of the house is cathedral ceiling. No ridge vent installed originally. Do ridge vents suffice in cathedral ceiling area?
Novar is offline   Reply With Quote
Old 04-24-2009, 11:26 AM   #2
This plywood is for the gussets? Shouldn't be a problem to upgrade to exterior ply 1/2 or 5/8".
For a ridge vent to be effective, you will need intake vents in the soffit area.
Ron
Old 04-24-2009, 08:24 PM   #3
Xtreme DIY'r
I use 3/4" even with 16" OC
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Ready to paint the porch! Oil or latex? Leah Frances Painting 8 07-26-2011 08:29 PM
Replacing Carpet on Stairway with Wood jkirby39 Carpentry 3 01-24-2009 01:42 PM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 12:19 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
