Replacing Roof Turbine Cap - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-28-2012, 04:49 PM   #1
Angry
Replacing roof turbine cap
My question is, will the screw holes in the base be useable to screw on the new cap, or should new holes be drilled into the base?
Also, any suggestions about removing the caulk (or whatever this stuff is) that's between cap and base of turbine? Half of the turbine cap fins were crushed after a tree limb fell on it, but there's no damage to base.
Thank you!
Jinjin is offline   Reply With Quote
Old 07-28-2012, 11:54 PM   #2
Rewards Points: 13,300
Why even bother. Remove the whole thing, fix the whole in the roof and add a ridge vent.
Looks a whole lot better, vents the whole roof not just a small circle.
To ansewer your question, just replace the whole unit. Not even sure where you would ever find just the top part.
Old 07-29-2012, 09:11 AM   #3
jinjin
Joe, I like the turbine so I'll replace it, hence my query.
Old 07-29-2012, 01:00 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,972
Elbow grease for the old caulk and just use a larger screw for the base.
Replacing shed roof phishfud Roofing/Siding 0 07-17-2011 01:35 PM
Replacing shingled roof with metal roof myminpins Roofing/Siding 3 06-26-2011 10:43 AM
Replacing Roof with Certainteed.Replace existing Ridge Master ridge vent? JW Johnson Roofing/Siding 4 11-06-2009 09:59 AM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 08:33 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
