Replacing A Patio Roof - I Can't Diy - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-22-2012, 01:54 PM   #1
replacing a patio roof - i can't diy
Hello,
I'm trying to get a rough idea of repair cost for our patio roof. It has an existing rolled roof that is starting to leak. The previous owner hired someone to install the roof and used nails that are now starting to pop out hence the leak.
Unfortunately, this is way over my head as far as DIYing. I can't get up on the roof . Anyways, I called around for repair estimates and the common scope is tear off the old material and replace with peel and stick mule-hide. The area is about 500 sq ft in arizona. Cost about $1500 materials and labor, licensed/bonded contractor bids.
Thanks for any input. If I missed something, please let me know.
Thanks!
eibyer is offline   Reply With Quote
Old 05-22-2012, 02:49 PM   #2
Roofer Mike
Arizona
$1500 for 500' sq ? Wow, that's cheap. In Miami roofers would need to charge at least $2500 for that scope.
Note to self:Don't...move...roofing...business...to...Ariz ona!
Pssst...roofing is regional...
roofer mike
http://www.roofermikeinc.com
roofermikeinc is offline   Reply With Quote
Old 05-22-2012, 03:01 PM   #3
Doing This Way Too Long
Rewards Points: 532
Very cheap for N. Idaho too.
That proposal will be 1000x better than what you have up there now. Make sure they address damaged/rotted sheathing.
OldNBroken is offline   Reply With Quote
Old 05-22-2012, 03:43 PM   #4
Thank you both for your feedback. It is noted in the work proposal that 4 sheets of plywood is included with the bid. I take it this will replace any of the damaged/rotted sheathing?
Old 05-22-2012, 10:33 PM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,554
Couldn't and wouldn't do it for that.
That is a smoking price so make sure everything is right.
Old 05-23-2012, 02:13 PM   #6
RFN-4A-LVN
Roofmaster417's Avatar
Pretty cheap.
$300 per sq. with materials running about $200 plus per square ? Someone is mighty hungry.
Roofmaster417 is offline   Reply With Quote
Adding drip edge to low-pitch patio roof Joboo Roofing/Siding 13 08-07-2016 07:35 PM
rubber roof over tar & thoughts on quote wfmrules3 Roofing/Siding 13 10-16-2011 09:00 PM
Replacing roof over porch ThatDaveGuy Building & Construction 0 02-20-2011 08:56 AM
Attached Patio Overhead Roof Gandalf Building & Construction 8 04-19-2010 11:53 AM
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 12:35 AM
