#1 |
Replacing a partial piece of roof vent??
When we had our old shingles replaced the man we hired to do it, replaced the ridge vent. However the ridge vent does not go all the way to the chimney. In fact it is about a foot and half away. It now leaks in that spot. Is there a way to replace just the missing piece of ridge vent or a way to stop it from leaking?
#2 |
the lack of a ridge vent is not causing your leak
#3 |
It is not the root cause, I know. That however is the part of the roof that is leaking and is only covered by shingles.
#4 |
The cut from the ridgevent should fall short of the chimney,just as it should at the gable ends.Some roofers also choose to to run the ridgevent short as well,which IMO looks very tacky.We always run all the way.This being the cause of the leak?Maybe a pic would help.It all depends on how its roofed in I guess.Anything is possible
| Display Modes | |
| Cobra Roof Vent | Coral Kemp | Roofing/Siding | 3 | 09-02-2010 12:00 AM |
| Help with Replacing a Roof in Arizona where the AC Unit is mounted on the Roof ! | stevekevin | Roofing/Siding | 7 | 05-24-2010 12:55 AM |
| How hard is it to add a roof vent with no experience? | Red Squirrel | Roofing/Siding | 3 | 05-18-2010 10:35 PM |
| Putting a new flat roof on a 3600 sf home | Jean3 | Off Topic | 2 | 04-09-2010 01:35 AM |
| Removing Plumbing Vent from Roof | WaldenL | Roofing/Siding | 5 | 08-24-2009 03:30 PM |
