Replacing Mudroom Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-07-2009, 08:24 AM   #1
replacing mudroom roof
I have to replace the roof of our mudroom, which is about 6 X 8 ft. and currently has a slightly sloping flat roof covered with tar-paper and is attached to a main outside wall and sealed with flashing. It currently leaks a little bit and therefore it needs to be replaced. I would like a short term fix, i.e. to fix the leaking problem but do not want to spend a fortune since the mudroom itself is pretty old and will need to be replaced before too long. I am not very handy and therefore would like to get some advice on a relatively simple way for me to do this. Should I try to replicate the existing sloping roof or try something else? Sorry if there is an existing post already on this subject.
mgwozdecky is offline   Reply With Quote
Old 06-07-2009, 09:17 AM   #2
How about a bucket of tar.
Josh Jaros Remodeling in The Woodlands, Texas www.jarosbros.com
jaros bros. is offline   Reply With Quote
Old 06-07-2009, 09:31 AM   #3
which would have been a perfectly reasonable solution, except that my wife would like something a bit more elaborate.
Old 06-07-2009, 09:54 PM   #4
Tar is a short term fix
A long term fix is replacing the roof
Which fix are you looking for?
Very hard to give any recommendation without a pic of the roof(s)
Tags
mudroom , replacing , roof
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 08:33 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 05:08 PM
Replacing a laundry room roof. Tomcat1066 Building & Construction 5 11-11-2006 04:08 PM
