Replacing Metal Back Borch Porch With Shingles - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-21-2008, 10:56 PM   #1
replacing metal back borch porch with shingles
5 years ago I had a metal roof put on my home...when the contractor put the metal on over the shingles,,,when he got down to the back porch he slipped a piece of metal under the old singles and attached it to the new metal roof by nailing it to the high part of the rib....The back porch has leaked in the valley for the last two years and the roofer is out of buisness (no wonder)..I want to replace the back porch roof with conventional shingles....what do I do with the piece of metal that he slipped underneath the old shingles and nailed to the high part of the rib on the back porch of my house
nurse47557 is offline   Reply With Quote
Old 05-21-2008, 11:10 PM   #2
Is all the metal nailed?You will need a transition flashing where the 2 roofs meet,I would have the old one removed and replaced.The metal should go under the top section(the more the merrier)and your new roof under the flashing.You might have to get this custom bent depending on the transition.I think I understood you,if not just give me hell.Take care-John
johnk is offline   Reply With Quote
replacing 12 yr. old ELK Prestique shingles bulldog50 Roofing/Siding 4 04-13-2008 08:25 PM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 08:46 PM
porch post vinyl or metal to stop painting? hobbyguy2002 Building & Construction 2 01-28-2008 03:37 PM
Porch re-construction - replacing 2x6's robertmee Building & Construction 2 11-15-2007 06:47 AM
