Replacing Low Pitch Rolled Roof Material - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-16-2008, 04:55 PM   #1
Rewards Points: 133
Replacing Low Pitch Rolled Roof material
Ok, On my porch it looks like the current rolled roofing is very near the end of it's life expectancy, so I am wondering what options I have to replace it? I would probably want to use some of the Self Adhesive rolled roofing material, but was wondering what kind I should look at.
Also, Do I need to remove the old one, or can I install the new one right over it?
And is there anything special to note when installing it?
jimmyfloyd is offline   Reply With Quote
Old 10-16-2008, 05:03 PM   #2
Doing This Way Too Long
Rewards Points: 532
Certainteed flintlastic SA. Excellent system. Do not skimp, do the full 3-ply system.
Of all types of roofing, I'd say SA's are probably the most DIY friendly system out there. Common sense and follow directions and you should get a fine job out of it.
Yes, you should remove the old roofing and start with a clean slate. One nice thing about flintlastic is it starts with a nailed base so you don't have to worry about a new surface to adhere to because it is not adhered. Also they have a decent color selection.
OldNBroken is offline   Reply With Quote
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 05:08 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
What roofing material is right for me? Grumpy Roofing/Siding 0 07-07-2004 08:41 PM
