Replacing Hardiplank Siding... - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-26-2010, 05:08 PM   #1
Exclamation
Replacing Hardiplank siding...
Does anyone know where I can find a video showing how to replace damaged hardiplank boards? I have found instructions, but would like to see it done before I start yanking boards off of the side of the house.
herbtown is offline   Reply With Quote
Old 09-26-2010, 09:18 PM   #2
Rewards Points: 5,336
Check out You tube.
Ron
Old 09-26-2010, 09:20 PM   #3
what is it that you are unsure of? Cutting? nailing?
wnabcptrNH is offline   Reply With Quote
Old 08-16-2015, 06:37 AM   #4
Rewards Points: 2
I'm trying to find the same thing.
2 bottom planks of my Hardi siding were damaged. How do I fasten replacement boards? My planks were nailed at the top and I've read you can't do both.
pjmlacy is offline   Reply With Quote
Old 08-19-2015, 11:37 AM   #5
Rewards Points: 30
There's a YouTube channel called TheHandymanToolbox. I think they also covered your question.
Jessy156 is offline   Reply With Quote
Replacing Wood Siding WIth Foam Backed Vinyl xludan Building & Construction 1 05-21-2009 06:27 PM
Hardiplank siding Clutchcargo Building & Construction 15 04-04-2008 05:17 AM
Replacing Wood Panel 4'x8' Siding Chevmann99 General DIY Discussions 5 10-02-2005 07:43 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
