Replacing A Cedar Shake Roof With Asphalt Shingles - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-08-2010, 09:58 AM   #16
Grumpy's Avatar
Rewards Points: 508
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
Originally Posted by spiragui View Post
Grumpy,
I understand using I&W in the valleys, as a leak would be hit the I&W and then run down the slope to the eaves
If I install I&W around say a plumbing flashing, would that not just direct a potential leak from the flashing to further down the sheathing (unless you run the I&W all the way to the eaves too)? Do I need to think more like a rain drop?
Cheers
Chris
At this point, I really think you need to call a licensed certified roofer. The little details are more than can be explained with words.
I guess the only advice left to give is what I tell the new guys... Water rolls down hill, pay day's on Friday. Remember that you'll do ok.
-Grumpy http://www.illinoisroofinspections.com
The information found in this post is not to be considered legal advice. The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
The Following User Says Thank You to Grumpy For This Useful Post:
kwikfishron (07-08-2010)
Old 07-08-2010, 02:48 PM   #17
these golden words were magical with figuring out skylight flashing
racebum is offline   Reply With Quote
Old 07-08-2010, 07:31 PM   #18
kwikfishron's Avatar
Rewards Points: 188
Isn’t that the truth.
Water does run down hill “until” of coarse you have winds in excess of 70 mph thus creating a negative pressure within the house that will actually suck water up hill, under the felt (wall or roof) and create that mystery leak.
Those are the fun ones to troubleshoot.
Back to the little details.
You got the new kid on the roofing crew, worked all summer maybe two and then goes to roof dads house and still screws it up. Looks just fine but there’s just that one little leak.
kwikfishron is online now   Reply With Quote
Old 07-08-2010, 08:20 PM   #19
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
It's all in the details.
seeyou is offline   Reply With Quote
Old 07-08-2010, 08:21 PM   #20
Grumpy's Avatar
Rewards Points: 508
Anyone can shingle. It's the details that take knowledge.
Restain roof deck without damaging asphalt roof safetycut Roofing/Siding 0 03-10-2010 12:54 AM
Replacing Cedar Shingles tstanley Roofing/Siding 2 03-09-2010 03:52 AM
Remove Pipe Vent from Asphalt Shingle Roof WaldenL Roofing/Siding 5 09-26-2009 02:46 PM
Replacing clay tile roof with shingles Sparky 55 Roofing/Siding 1 03-26-2009 11:08 PM
Re-roofing house questions (Currently have Cedar shake w/ 1x6 slats) techjap Roofing/Siding 1 05-02-2008 11:53 PM
