Replacing Below Ridge Roof Vent Damaged By Wind - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 02-01-2012, 06:15 PM   #1
Rewards Points: 866
Replacing below ridge roof vent damaged by wind
I have to have a sheet metal below ridge vent replaced due to wind damage. I may do it myself but will probably hire a roofer if I can find one I trust.
It is a concrete tile roof in the Mediterranen style. A roofer that came out and covered things with an emergency tarp for $350 has given me an estimate for an additional $1200 to do the repairs. Two items he proposes concern me.
1. He wants to R&R the felt up to and under the ridge cap. I do not believe he knows if it has been damaged or distrubed by the wind.
2. Before replacing the felt all "protruding nails will be pounded down". Somewhere I believe I heard that this could cause a problem.
I asked the insurance estimator and he not only thought that they should not be pounded down, but unless the existing felt is badly damaged it should be left in place and a layer of felt should be laid over the existing felt. This is the original roof and there is only the one layer now present. I notice the actual estimate allows nothing for felt.
Some pictures of the damaged area are found at https://picasaweb.google.com/101682836359758483878/January262012?authuser=0&authkey=Gv1sRgCPHc3oy1ucG NIA&feat=directlink
Do you guys have any suggestions? Does it sound like the roofer knows what he is doing or is he just inflating his bill? Thanks.
Klawman is offline   Reply With Quote
Old 02-01-2012, 08:49 PM   #2
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
OK - Tile roofs are more dependent on the underlayment than other roofs. I never do any tile repairs without making sure the underlayment is in good shape. If it were ice and water shield rather than felt, I might not replace it. Felt, yes. There will be holes left in it from the original install.
As far as the pulling or pounding nails, he's given you too much information. If I were to remove the underlayment, I'd pull the nails to make removal easier. If I were leaving the underlayment, I'd pound the nails so no nail holes were in the underlayment. Since it's a repair, some nails should be pounded, some pulled.
seeyou is offline   Reply With Quote
The Following 2 Users Say Thank You to seeyou For This Useful Post:
Klawman (02-01-2012), Roofmaster417 (02-01-2012)
Old 02-01-2012, 08:56 PM   #3
Rewards Points: 866
Thanks seeyou. I might have added that I am in Southern California where we never see ice or snow and very little rain.
Old 02-01-2012, 09:11 PM   #4
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
You don't hardly even need a roof then.....
The Following User Says Thank You to seeyou For This Useful Post:
Old 02-01-2012, 09:14 PM   #5
Rewards Points: 866
The roofs help to keep the loonies out of the pharmaceuticals
Old 02-01-2012, 11:05 PM   #6
RFN-4A-LVN
Roofmaster417's Avatar
Hahahahaha.,Nice
You could always leave it alone and keep the tarp handy.
Roofmaster417 is offline   Reply With Quote
snow country ridge vent on 2:12 pitch roof fxtm Roofing/Siding 4 11-01-2011 07:26 PM
Roof leak nightmare..... it won't stop amandat37 Roofing/Siding 52 04-22-2011 01:47 PM
Replacing a cedar shake roof with asphalt shingles spiragui Roofing/Siding 19 07-08-2010 08:21 PM
low-slope roof and leaky ridge vent downers Roofing/Siding 15 02-22-2008 12:35 AM
sagging roof, rotten ridge board sonoflee Roofing/Siding 6 01-29-2008 07:12 PM
