-   -   replacing ashphalt with cedar shingles - small roof (http://www.diychatroom.com/f9/replacing-ashphalt-cedar-shingles-small-roof-86416/)
christy123 11-10-2010 11:31 PM
I am in the process of replacing a small roof ...sort of a lip over first floor..about 2 1/2 deep with cedar shingles...my contractor says he has done it before but i have doubts....i researched online ...got some good idea but am still confused.
most likely the current sheathing is plywood...does he need to put felt underneath...if yes , does felt need to cover entire area or does he need to leave some gaps for ventilation..this got me confused. also, i learnt that the first row should be double..is that true?
thanks
christy
christy123 11-10-2010 11:41 PM
that is 2 1/2 ft
johnk 11-11-2010 01:39 AM
http://www.cedarbureau.org/ all the info you need to know...and alot more:)
christy123 11-11-2010 01:01 PM
i looked at it already..it got me confused. obviously not too bright!
Daniel Holzman 11-11-2010 03:24 PM
If that site is confusing, you may want to purchase a book on roofing. The more pictures the better. I just installed about 120 square feet of cedar siding, this is a material that is a bit tricky to work with, since it can break easily, it can curl, and it is not dimensionally identical from piece to piece. Best to get a book that discusses all the ins and outs before you start work. If you are just trying to get up to speed so you can discuss the project with your contractor, a book would be good for that too.
christy123 11-11-2010 06:01 PM
the reason i got confused is because i dont know the technical lingo...u are right i would need a book with a lot of pics.
folks on this board have been very helpful...so i am hoping someone will come up with the right answer.
johnk 11-11-2010 11:33 PM
thanks
christy
The first row should be doubled,but can be tripled.Felt one course at eaves only.
johnk 11-11-2010 11:34 PM
This is for shingles and not shakes.
christy123 11-13-2010 04:42 PM
we are using shingles not shakes actually.. would it cause any problem if we completely cover the surface with felt?
Ed the Roofer 11-13-2010 06:11 PM
No, not significantly if I understand the structure they are being applied to correctly from your description.
Is this an approximate 2 foot 6 inch ribbon decorative roof extending behond the exterior wall of the home?
If so, then ventilation will not be a concern.
But, the flashing detail where the sheet metal roof to wall angled apron metal goes would be.
Ed
christy123 11-13-2010 09:05 PM
Ed...you are correct...it is the decorative roof and you described it with 100% accuracy.
There is metal flashing already there...are you asking iif this flashing is present or not?
thanks
christy123 11-13-2010 09:20 PM
i found the answer in the video that is posted on cedarbereau site. they suggest that felt should be put under non-exposed part of the shingle only. As Ed pointed out, this roof is decorative ..so we may not have to follow these guidelines
Ed the Roofer 11-15-2010 07:30 PM
The Cedar Bureau site is a good one and I think you have the answers you need.
The only thing I commented about as far as the roof to wall metal apron flashing goes, was to ensure that there was one in place and that it is re-usable or will be attended to if it needs to be replaced.
It is not critical as far as interior leakage goes, but you wouldn't want the overhang to get corrupted with moisture infiltration from an ongoing, albeit, slow and continual wall leak.
Good Luck,
Ed
