Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing/Siding
Old 02-03-2012, 09:56 AM   #1
replace sheathing or let dry?
There is a small leak in my roof at the skylight. There is a small section that is the width of the skylight (~16" long) and maybe 6" wide where the sheathing is wet and some of the "wafers" are peelign off the sheathing.
Obviuosly I wish this wouldn't have happened in the first place, but...If i seal the skylight so that the leak is stopped and the sheathign is allowed to dry, does that section of sheathing need to be replaced? Structurally it is such a small area and it is next to a skylight so does the sheathing need to be replaced in that area?
thanks, Dan
The Gopher is offline   Reply With Quote
Old 02-03-2012, 10:15 AM   #2
Exterior Construction
Windows on Wash's Avatar
Should be able to dry to the interior of the attic pretty easily.
If it was just temporary, I wouldn't worry about sheathing rot.
Old 02-03-2012, 10:58 AM   #3
if i did need to replace this portion of sheathing, does anyone have a guess on a price from a contractor? of course it can vary a lot i'm just wondering if it will be 300 bucks or 1000 bucks?
Old 02-03-2012, 02:52 PM   #4
RFN-4A-LVN
Roofmaster417's Avatar
Try running a dehumidifier in your attic in that area if possible.The dehumidifier will draw out the moisture.It also helps pull that moisture out of insulation and the top of the drywall and decking. (Attic)
I use a dehumidifier with alot of our storm damage.The insurance companies pay me to run it in the attics,basements,bedrooms etc. where leaking has occurred.
I would run the dehumidifier for about 12 hours depending on the leak.Afterwards I would treat the area with an anti-bac.,but you can just use 1 part bleach with 3 part water.
Just spray the affected areas with a mist that will coat the area not to the point of saturation.
If it is a very small area I would save my money on a repair.,buy a dehumidifier for about $125.They really come in handy.So $125 for the unit,$8 for a garden hose,,$2 for a spray bottle,$2 for bleach and a little effort and you saved some money and treated the areas.
Roofmaster417 is offline   Reply With Quote
removal of exterior sheathing to apply spray-foam insulation from the outside raymaccallum Building & Construction 4 03-24-2011 06:52 PM
Replace 2x4 rafters? rgb407 Roofing/Siding 7 03-13-2010 06:17 PM
New roof and Sheathing - Install new fascia before or after? hartkem Roofing/Siding 2 06-01-2009 01:12 PM
Moisture on Inside of Sheathing elburritoloco Building & Construction 18 01-19-2009 09:16 PM
Please, help with sheathing and stud placement Mrmusic Building & Construction 2 09-10-2008 05:52 PM
