Replace Rolled Roofing With Shingles - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-01-2014, 10:32 PM   #1
Rewards Points: 33
Replace Rolled Roofing with Shingles
Hello,
I was wondering if someone with more knowledge can point me in the right direction. I have a 2 year old shingled roof in good condition. Recently I took down an old deck the had a roof. The transition from my garage roof to the deck roof has rolled roofing. Now that I have taken the deck roof down I am left with the garage roof having a portion of rolled roofing that I need to replace with shingles. This only requires about 2 rows of shingles. In addition I will need to replace the fascia wrap, drip edge and add gutters as well. The section is about 20 feet long.
I assume that the steps are
Remove rolled roofing
Add drip edge
Add Fascia
Add shingles
Add gutter.
I was wondering if there is a layer of felt paper or underlayment I need to add or if there are any important parts I am missing.
Thank you
Lenny
Leonidsg is offline   Reply With Quote
Old 05-02-2014, 06:36 AM   #2
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
That looks too flat for shingles. Need more pix.
tinner666 is offline   Reply With Quote
Old 05-02-2014, 07:06 AM   #3
Rewards Points: 33
What kind of picture would be helpful. The other side of he garage has shingles. I think the pictur is deceiving because there was still a little portion of the deck roof attached. I'll take a better one. Any other pictures that will be helpful.
Thank you
Lenny
Old 05-02-2014, 09:01 AM   #4
Rewards Points: 12,856
There is no need to remove the old rolled roofing beyond the house roof rafter tails.
It will act like storm and ice shield and will save some work and materials.
Fascia goes on before the drip edge.
If possible slip the drip edge up under the rolled roofing.
Old 05-02-2014, 09:11 AM   #5
Rewards Points: 33
Do I then add shingles to the rolled roofing?
Old 05-02-2014, 09:28 AM   #6
Rob
Robpo's Avatar
Rewards Points: 826
From the pic it looks like this part doesn't have enough pitch. If that part is removed no problem.
Robpo is offline   Reply With Quote
The Following User Says Thank You to Robpo For This Useful Post:
joecaption (05-02-2014)
Old 05-02-2014, 09:48 AM   #7
Rewards Points: 33
Correct that part has since been removed. I can upload a picture when I get home.
Thank you
Old 05-05-2014, 09:27 PM   #8
Rewards Points: 33
Updated Pics
It looks like I will only need a couple rows of shingles. There is a drip edge but I think I will replace it so that it is white, I will also replace the fascia wrap. Would it be best to just attach the shingles over the rolled roofing. If so where should I cut the edge of the rolled roofing to.
Thank you
Replace Rolled Roofing with Shingles-photo-1.jpg   Replace Rolled Roofing with Shingles-photo-2.jpg   Replace Rolled Roofing with Shingles-photo.jpg
Old 05-09-2014, 08:46 PM   #9
Rewards Points: 33
Any additional help would be very appreciated. Thank you
rolled roofing??? us masonry Roofing/Siding 5 11-05-2010 11:15 PM
roofing shingles jetmech Roofing/Siding 0 11-05-2010 09:20 AM
Rolled Roofing Leaking and Leaking DIYNewbee Roofing/Siding 9 12-13-2009 10:46 PM
rolled roofing product charliebrown314 Roofing/Siding 1 03-12-2009 01:30 AM
Matching Shingles and Rolled Roofing crankitup Roofing/Siding 2 01-31-2008 01:33 AM
