Replace Part Of Cedar Roof With A Matching Shingle - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-21-2012, 11:15 AM   #1
Replace part of Cedar roof with a matching Shingle
I have a cedar roof- probably 30 years old. we put on an addition about 7 years ago and matched the cedar. Now we need to replace the older roof and want to use an architectural shingle, in the hope that it will be cheaper and easier to install. What product is out there, and how do I match the weathered look of the shingle in terms of texture and color? Thanks so much
lora8333 is offline   Reply With Quote
Old 09-21-2012, 01:18 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,928
Taking of cedar and putting back asphalt is always a bit sad to see.
You really loose a good bit of the look of the home when you ditch the shakes.
Have you considered a metal roof?
Old 09-21-2012, 09:45 PM   #3
Rewards Points: 13,300
Could also go with a faux slate roof. There made out of recycled tires and looks exactly like real slate.
Torching part of shingle based roof at hog valley daluu Roofing/Siding 5 09-11-2012 07:27 PM
Need Advice ASAP. New home, seller is paying to replace roof elpa Roofing/Siding 4 02-18-2010 08:03 PM
Shingle Roof Replacement Questions - Overlay vs Tear-Off /OC vs Tamko tecboy Roofing/Siding 12 06-28-2009 07:09 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
Insulating under part of my Flat Roof Hushpuppy Roofing/Siding 5 02-13-2006 03:45 PM
