Replace Damages Shingle - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-15-2013, 03:43 PM   #1
Rewards Points: 194
Now that it is summer and we (at least us in California) won't be having any rain for a while, I'm thinking that it is time to fix a roof issue that I noticed last winter.
I have a single shingle that needs to be replaced. The type of shingle is a Certainteed Presidential asphalt shingle, and luckily I have some spare shingles in my garage. For some reason, one of the shingles on the first course (right above the rain gutter) wore out and damaged faster than the others and it needs to be replaced. A lot of water gets funneled to this area, so maybe it just wore out faster? Who knows...
I've never replaced just one shingle before--is it as easy as just lifting the shingles above, popping the nails, and then sliding the new piece in? If so, how would I put new nails in without having them exposed on the tops of the other shingles? Do I just need to carefully hammer the new nails under the other shingles and hope that I don't rip the good shingles?
Any tips are welcomed!
loftezy is offline   Reply With Quote
Old 08-15-2013, 08:18 PM   #2
Dallas Roofing Company
The answer to your question; Do I just need to carefully hammer the new nails under the other shingles and hope that I don't rip the good shingles, is yes. I would wait for a warm day so that the shingles have a bit more of flexibility. You want to take out the nails from the above row shingle to properly fit in the new shingle. Make sure to take out the nails and not leave in decking or else it can make it difficult to slide in the new shingle. You will hit the nail as your sliding the new shingle into place.
Devin Mahdi
Dallas-Roofing is offline   Reply With Quote
Old 08-15-2013, 11:48 PM   #3
Rewards Points: 194
That's kinda what I expected. Thanks for the tip about the existing nails, it probably saved me quite a bit of frustration!
Must I replace the coil when I replace the outside condenser unit? plichtenstein HVAC 5 08-24-2010 03:41 PM
Need Advice ASAP. New home, seller is paying to replace roof elpa Roofing/Siding 4 02-18-2010 08:03 PM
Corner of Shingle Broke Off sweaty Roofing/Siding 1 09-09-2008 10:11 AM
about to replace my porch roof wombosi Roofing/Siding 5 08-21-2008 11:58 PM
shingle vent II and hip roofs tie in dondiy Roofing/Siding 2 08-11-2008 01:40 AM
