Replace Or Cover Masonite Siding - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-22-2014, 06:38 AM   #1
Rewards Points: 33
Replace or Cover Masonite Siding
Hey all,
My 35 year old house that I moved into last month has masonite siding. It's ugly, was installed poorly and tearing up near the base due to wear and who knows what else. I'll get my bonus and a hefty tax return next year and I'm going vinyl or fiber cement (depends on final cost).
A couple people suggest that I should just cover the masonite instead of replacing it. I am open to this idea but an unfamiliar with siding. Is there any risk of having the masonite underneath the new vinyl?
bigbopper180 is offline   Reply With Quote
Old 04-22-2014, 10:14 AM   #2
Rewards Points: 13,712
Masonite had a recall many many years ago from all the moisture issues.
I for sure would not leave it on.
It's just going to mold up behind the new siding and throw off all your window and door trim.
Once it's gone make sure to use house wrap before the siding.
Old 04-22-2014, 10:49 AM   #3
Rewards Points: 774
Originally Posted by bigbopper180 View Post
Hey all,
Are you siding it yourself? I would probably tear the old stuff off. You're saving time and labor (if you don't want to take the old stuff off), but you're leaving yourself open to other issues.
Someone had the great idea to do what you are considering to my own house.....twice. Now I have 3 layers of siding and a huge mess to figure out.
Do it right the first time and take it off. It's not hard...just a bit of labor. No matter what material you side with you need a nice, flat, even surface.
cibula11 is offline   Reply With Quote
Old 04-22-2014, 03:18 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,628
Tear it off.
Old 04-22-2014, 03:29 PM   #5
kwikfishron's Avatar
Rewards Points: 586
As far as extra labor is concerned, It doesn't get much easier than tearing off lap Masonite.
kwikfishron is online now   Reply With Quote
Old 04-23-2014, 09:40 AM   #6
Rewards Points: 774
No kidding.
Just make sure to have a place to dump it or burn it. If it gets wet, it'll fall apart and be a huge mess.
Old 04-23-2014, 10:35 AM   #7
Rewards Points: 2,044
If you try to put vinyl over the top of Masonite, the Masonite cracks and falls between the outer layer and the inner layer, leaving you with a very uneven appearance, I have done both at the homeowners behest, those that wanted it left on were always disappointed. Often paid extra to remove the new and start over.
So TEAR IT OFF FIRST.
ED
de-nagorg is online now   Reply With Quote
Tags
masonite
Should I replace my vertical cedar siding? mpnret Roofing/Siding 20 09-13-2014 08:55 AM
Patio Cover and vinyl siding? r_halleman Building & Construction 7 03-30-2013 12:55 PM
Masonite type stucco siding Cmeller Carpentry 3 03-28-2011 10:15 PM
Screw holes in vinyl siding piece due to awning removal - fill or replace? mark2741 Building & Construction 9 03-24-2011 12:21 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
