Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 09-24-2010, 11:22 AM   #1
uas
repairs ro duro last
I have tenants that decided to use the lower duro last roof as an ashtray and now I am left with dozens of tiny burn holes all over. My thought was to take a large 10x20 section and heat weld a big band-aid that covers all the holes (there is a deck/walkway on the roof and replacing that would be too expensive at this time)? Any thoughts/Suggestions/recommendations? Can I do this myself using another material (since I cannot get duro last without going to a contractor). Any recomendations on who to use in the Appleton/Neenah, WI area? HELP!!! I'm looking for ways to make this roof last for another 2-3 years and replace it with the upper (it has already lived 20 years and is in amazing shape for a 20 yr roof).
uas is offline   Reply With Quote
Old 09-24-2010, 05:24 PM   #2
The Duro Last roof should still be under some sort of manufacturer warranty. Although the burn repairs would not be covered under the warranty, a Duro Last approved contractor would need to make the repairs if you want to maintain the warranty on the roof system.
The repair that you describe would probably work fine. Duro Last is a PVC-based single ply and uses hot-air welds to fuse the material together in the field. Hot air welding is not really a skill for a DIY'er as it takes specialized hot-air guns (the ones you get at Home Depot or Lowes wont work) and lots of practice. Just as in welding metal, the wrong temp. burns holes or leaves false welds.
If you dont care about the warranty stuff, you might be able to hot-air weld another PVC-based membrane (TPO WONT WORK!) but you are still stuck with the welding issue. You might be able to chemically weld it (I'm from the old school Trocal days!) but I have never tried it with Duro Last so I dont know if it would even work. You might consider OMG Everseal or MFM Peel & Seal and try and patch things with these self adhering membranes. Properly installed, they should be worth a couple years Just make sure you get the Duro Last good and clean before adhering the patches.
Luv2Roof is offline   Reply With Quote
Old 09-24-2010, 09:11 PM   #3
Doing This Way Too Long
google Eternabond if you want to do it yourself. It's like duct tape on steroids
OldNBroken is offline   Reply With Quote
Old 09-27-2010, 08:50 AM   #4
I've patched holes in durolast with silicone caulk, so far so good.
rodeo is offline   Reply With Quote
Old 09-28-2010, 02:19 PM   #5
If you would like to contact me, I'd be glad to help you contact a certified Duro-Last contractor in your area and possibly even the contractor that orginally installed the material.
As one of the other posts mentioned, we don't want anything to be done with the Duro-Last material that may alter the warranty. Thus it is best to deal with a certified installer.
Feel free to reply to this thread, email me at kclaes@duro-last.com or call 800-248-0280 x1080. Thanks.
Kenneth Claes
MidWest Regional Coordinator
kclaes is offline   Reply With Quote
duro last flat roofing cherylfromcanada Roofing 4 08-06-2012 12:19 PM
New Automotive Repairs Forum Nathan Automotive Repairs 3 10-29-2010 02:28 PM
entry door repairs or replace? mudpaws Carpentry 8 06-08-2009 10:13 AM
Bicycle Repairs Chemist1961 General Discussion 11 05-27-2009 08:34 AM
An idea on repairs? (Buying a Fixer Upper Home) kelly001 Building & Construction 15 10-03-2006 05:38 PM
