Repairing TIN Box Gutters - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-11-2010, 09:26 AM   #1
Repairing TIN Box gutters
Hello,
I have a duplex located in Pittsburgh with tin box gutters on all four sides. I have a leak at the seam on the west side causeing water to pour throught the soffit. I am fairly handy so if I get the right advice I am sure I can repair it. I just don't know what product to use. I understand that silicone and the roof repair in a tube are not the correct choices. I do not want to solder the seam or solder patches. Although it looks like this was originally done.
The tin has not been painted for at least 15 years, but appears to be in good condition.
Thanks in advance for any suggestions.
tanker135 is offline   Reply With Quote
Old 11-11-2010, 01:45 PM   #2
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
If it's a burst seam, use Geocel 2315, available at roofing supply stores. It's a brushable product.
seeyou is offline   Reply With Quote
Old 11-11-2010, 05:04 PM   #3
I will look for the Geocel 2315. Also, if I found holes in the tin what is the solution for that problem?
Old 11-11-2010, 06:02 PM   #4
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
2315 will patch pin holes. If the hole is so large that the 2315 drips through, cut a piece of terne, galvanized, or stainless and embed it in the 2315. Let dry and apply another coat. The 2315 takes paint well.
Old 11-15-2010, 07:04 PM   #5
tin boxed gutter repair
Tags
box gutters , roof repair , roofing , tin
Gutters and Decorative Trim on Fascia paulyg Roofing/Siding 12 07-27-2010 03:54 PM
new drip edge over existing gutters scheiman Roofing/Siding 1 06-05-2010 08:44 PM
Leaking Gutters fripster Roofing/Siding 5 02-13-2010 09:25 PM
Box Gutters Fix or Aluminum? jonathan03 Roofing/Siding 4 01-01-2009 01:42 PM
Do I replace my gutters? nymark Roofing/Siding 5 06-18-2008 10:36 PM
