Repairing Metal Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-16-2011, 06:25 PM   #1
repairing metal roof
I want to put new metal over old metal on my tool shed. Is this doable or must I remove old metal first?
pamsfarm11 is offline   Reply With Quote
Old 04-16-2011, 06:57 PM   #2
Rewards Points: 2,240
What kind of metal roof?
Pictures would be a good thing!
Welcome to "DIY"!
rossfingal
rossfingal is offline   Reply With Quote
Old 04-16-2011, 07:02 PM   #3
RFN-4A-LVN
Roofmaster417's Avatar
I have seen 2 layers of metal,I have never installed metal over metal.
What are the dimensions of your shed?
What type of metal is there right now?
The way I have seen it isn't very appealing.Existing metal with new boards with new metal going over that adds some weight.Several inches gap between the new metal to the existing will have to be considered.But metal accessories are available to address that issue.
With the weight factor coming into play,are your trusses and walls 2"x 4",or 2"x 6" or steel?
What material will you be using? What is the weight per sq.?
I personally IMO would not do it,but since it won't be a family dwelling you might get away with it.Personally I would not.
Roofmaster417 is offline   Reply With Quote
Old 04-16-2011, 07:46 PM   #4
Tom Struble's Avatar
Rewards Points: 2,002
http://www.roofhugger.com/
Tom Struble is offline   Reply With Quote
Roof leak nightmare..... it won't stop amandat37 Roofing/Siding 52 04-22-2011 12:47 PM
not venting a metal roof penny0322 Roofing/Siding 6 03-25-2011 05:39 PM
condensation leak with metal roof on cathedral ceiling in Canada Serialrenovator Roofing/Siding 10 02-02-2010 12:18 AM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 07:33 PM
Tired of patching my flat garage roof, I want to reroof it. Metal???? sellingitall Roofing/Siding 2 09-12-2008 08:51 PM
