Repairing Ends Of Roof Rafters - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-27-2014, 04:14 PM   #1
Rewards Points: 682
Repairing ends of roof rafters
Frequently I've seen roofers repair the ends of rotted roof rafters by cutting them off at the wall of the house and nailing a new piece in. While I can't think of a different way to do things, it does seem that new piece will have little structural strength, wouldn't help much in holding up the edge of the roof. What do you guys think.
darsunt is offline   Reply With Quote
Old 03-27-2014, 04:28 PM   #2
kwikfishron's Avatar
Rewards Points: 394
You need 2/3 of the sister attached to the rafter. I other words if you have a 2' overhang the new sister tail would need to be 6' in length with 4' of it attached to the existing rafter for it to be structurally sound.
kwikfishron is offline   Reply With Quote
Old 03-27-2014, 04:42 PM   #3
Rewards Points: 13,450
Depends on how long the over hang is what you can get away with.
Old 03-27-2014, 04:50 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,092
Very little weight is being carried at the roof edge.
As a general rule though, you will see them extend the repair approximately two times the length of the replaced section inward.
Old 03-27-2014, 08:40 PM   #5
roofermann's Avatar
Rewards Points: 401
What do I think? Jacklegs are doing the work.
roofermann is offline   Reply With Quote
shingle roof leak and hurricane questions paulmars Roofing/Siding 52 10-17-2013 10:08 PM
gravel tar roof repairing mazizbit Roofing/Siding 7 04-09-2012 09:52 AM
Roof leak nightmare..... it won't stop amandat37 Roofing/Siding 52 04-22-2011 12:47 PM
Roof bracing / pulling rafters together JoeT Building & Construction 8 07-08-2010 07:54 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
