#1 |
repairing cracks on a flat roof
I have a mid-century modern home with a completely flat roof. There are now some cracks in the roofing material, most are about 1/16" along the seams, but some are wider where the roofing material curves up to the metal edging (see attached pics). I'm considering doing a DIY repair job with Henry's 209 – ELASTOMASTIC® ROOF PATCH and the accompanying 183 Reinforcing Fabric. My goal is to just get through this So Cal winter, as I know that a new roof is overdue.
My questions are: 1 - Are the Henry's patching products I mentioned a good solution? 2 - Are my cracks too big to be patched? Thanks in advance for any advice. |
#2 |
Roofmaster
Do you have blisters in hot weather? Like air pockets (Bumps) on the roof?
" A lot of men build things, and a lot of things fall down " |
#3 |
Not really. Overall, the roof looks pretty good. There are some bumps where the roofing material was applied heavy, but no blisters.
#4 |
Low Slope Roofing
Nothing wrong with repairing it that way as long as you remember that it will not last forever.
#5 |
Windows & Remodeling
+1. Repair away, it will buy you some time, but ultimately you'll need to replace it.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#6 |
Doing This Way Too Long
Don't waste your money on that Henry's crap if you can help it. I would suggest going to your bldg supply or preferably roofing supply and getting some modified mastic and cotton webbing. Karnak has always been a decent mastic.
#7 |
Roofmaster
To repair things like the crack that you have shown, you are going to want to cut out the delaminated material. Remove all of the loose surface stuff that is scaling, as best you can. Brush the area to be patched with D-41 primer. Trowel on a thin coating of flashing cement. Embed 6 inch wide D-173 Asphalt Saturated Cotton Fabric in flashing cement centered on crack, and trowel in. Top coat with flashing cement. Trowel on second coat of cement, then embed 12 inch wide D-173 fabric. You need to use cotton, not fiberglass because it will conform nicely.
#8 |
Low Slope Roofing
I think a couple of people missed the part about only needed it to get through the winter in SO. cal....
FWIW Some of henry's products are actually pretty decent. |
#9 |
Roofmaster
I agree Sarge. The smartest thing that Henry did, and i gave them the idea, was to come out with a 2.5 gallon bucket of roof cement. Same diameter as a typical 5, half the depth, and weight. No black elbows.
![]() True story: I went to a distributor (SeaBoard) to pick up 30 cans of "Monroe" roof cement. I was apparently not supposed to go into one area of the warehouse, but I did. There sat cans with labels from abut 6 different sales entities and they were all being filled with the same mastic. The same thing happened when I worked in Bayway, the Exxon Refinery, (Whew, what a barren wasteland) all the tanker trucks from different fuel companies pulled up to the same watering hole. I dont see whay he only wants to get through the winter if he has no leaks, or blisters, but he has a bad design there because he does not have a raised edge at his gravel stop. The bituminous to metal tie in always fails first on BUR's from dissimilar movement. That's why parapet walls and internal drains are better.
" A lot of men build things, and a lot of things fall down " Last edited by jagans; 02-01-2013 at 02:37 PM. |
#10 | |
repairing cracks on a flat roofQuote:
#11 |
Sounds like a Henry's rep. Things may have changed in the past few years with their products that I am not aware of.
#12 |
looks like its already had some elastomeric put on it. id get some of the matting and go over the cracks with it, then put three coats on the whole roof. there now you have a new roof that should last for many many years.
#13 |
Fixer-'til-broker
Henry's stuff is TERRIBLE! I have the same scenario. The cheap local brand of "solarflex" is much thicker. After I patched the cracks it opened up and leaked again. It's better to just save some money replace the materials in the shoddy job.
"Aw! Why does everything that only happens to stupid people happens to me?" - Homer J. Simpson |
#14 |
Roofmaster
Test Dummy,
DId you embed asphalt saturated fabric into the cement and then top coat it? No roof cement will bridge cracks.
| Display Modes | |
| maintenance for a flat roof | ithinkican | Roofing/Siding | 8 | 03-23-2012 12:52 PM |
| Townhouse flat roof - Neighbor's contractor place huge weight of shingles on our roof | DIYInCT | Roofing/Siding | 2 | 11-23-2008 11:31 AM |
| Help with repairing a flat rubber garage roof | Toasty | Roofing/Siding | 2 | 07-01-2008 09:43 AM |
| Flat roof headache | The Barber | Roofing/Siding | 7 | 05-17-2008 06:48 PM |
| Where flat roof meets shingled roof | bstyer | Roofing/Siding | 1 | 07-07-2005 09:34 PM |
