-   -   repairing cracks on a flat roof (http://www.diychatroom.com/f9/repairing-cracks-flat-roof-170646/)
j_midcentury 01-31-2013 11:47 AM
2 Attachment(s)
I have a mid-century modern home with a completely flat roof. There are now some cracks in the roofing material, most are about 1/16" along the seams, but some are wider where the roofing material curves up to the metal edging (see attached pics). I'm considering doing a DIY repair job with Henry's 209 – ELASTOMASTIC® ROOF PATCH and the accompanying 183 Reinforcing Fabric. My goal is to just get through this So Cal winter, as I know that a new roof is overdue.
My questions are:
1 - Are the Henry's patching products I mentioned a good solution?
2 - Are my cracks too big to be patched?
Thanks in advance for any advice.
jagans 01-31-2013 12:05 PM
Do you have blisters in hot weather? Like air pockets (Bumps) on the roof?
j_midcentury 01-31-2013 12:10 PM
Not really. Overall, the roof looks pretty good. There are some bumps where the roofing material was applied heavy, but no blisters.
1985gt 01-31-2013 12:56 PM
Nothing wrong with repairing it that way as long as you remember that it will not last forever.
HomeSealed 01-31-2013 02:25 PM
+1. Repair away, it will buy you some time, but ultimately you'll need to replace it.
OldNBroken 01-31-2013 05:34 PM
Don't waste your money on that Henry's crap if you can help it. I would suggest going to your bldg supply or preferably roofing supply and getting some modified mastic and cotton webbing. Karnak has always been a decent mastic.
jagans 01-31-2013 07:32 PM
To repair things like the crack that you have shown, you are going to want to cut out the delaminated material. Remove all of the loose surface stuff that is scaling, as best you can. Brush the area to be patched with D-41 primer. Trowel on a thin coating of flashing cement. Embed 6 inch wide D-173 Asphalt Saturated Cotton Fabric in flashing cement centered on crack, and trowel in. Top coat with flashing cement. Trowel on second coat of cement, then embed 12 inch wide D-173 fabric. You need to use cotton, not fiberglass because it will conform nicely.
1985gt 02-01-2013 02:07 PM
I think a couple of people missed the part about only needed it to get through the winter in SO. cal....
FWIW Some of henry's products are actually pretty decent.
jagans 02-01-2013 02:33 PM
I agree Sarge. The smartest thing that Henry did, and i gave them the idea, was to come out with a 2.5 gallon bucket of roof cement. Same diameter as a typical 5, half the depth, and weight. No black elbows. :mad:
True story: I went to a distributor (SeaBoard) to pick up 30 cans of "Monroe" roof cement. I was apparently not supposed to go into one area of the warehouse, but I did. There sat cans with labels from abut 6 different sales entities and they were all being filled with the same mastic. The same thing happened when I worked in Bayway, the Exxon Refinery, (Whew, what a barren wasteland) all the tanker trucks from different fuel companies pulled up to the same watering hole.
I dont see whay he only wants to get through the winter if he has no leaks, or blisters, but he has a bad design there because he does not have a raised edge at his gravel stop. The bituminous to metal tie in always fails first on BUR's from dissimilar movement. That's why parapet walls and internal drains are better.
Chris Brink 02-10-2013 04:54 PM
Henry mastics have been extensively tested and proven to perform in a variety of conditions. Henry now offers warranties on certain of their products that the competitors do not offer.
OldNBroken 02-10-2013 09:38 PM
Sounds like a Henry's rep. Things may have changed in the past few years with their products that I am not aware of.
hotrod351 02-18-2013 08:48 AM
looks like its already had some elastomeric put on it. id get some of the matting and go over the cracks with it, then put three coats on the whole roof. there now you have a new roof that should last for many many years.
DIYtestdummy 02-26-2013 09:46 AM
Henry's stuff is TERRIBLE! I have the same scenario. The cheap local brand of "solarflex" is much thicker. After I patched the cracks it opened up and leaked again. It's better to just save some money replace the materials in the shoddy job.
:censored:
jagans 02-26-2013 10:06 AM
Test Dummy,
DId you embed asphalt saturated fabric into the cement and then top coat it? No roof cement will bridge cracks.
1985gt 02-26-2013 12:44 PM
Judging by it cracking again I would say not.
