Repair Already Installed Rolled Roofing - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-18-2011, 04:38 PM   #1
Repair Already Installed rolled roofing
My brothers and I installed rolled roofing on my mom's enclosed patio. We did not know what we were doing. We replaced two pieces of one inch plywood that was water damaged. Then layed down felt dry(ie without embedding into roof cement) nailed it down. Then layed down 90 # Roofing on top of felt. Roofing was also layed down dry without ebedding into roof cement. We nailed down the roofing. Please help cause I am really affraid that this roofing job is going to leak. Any and all suggestions are welcome.
Bob
bobmartinez is offline   Reply With Quote
Old 10-18-2011, 05:08 PM   #2
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Sounds like a leaker, all right. Google SBS self adhered roofing for the correct flat roof options and put down a nailable base, an inter-ply and the cap sheet after tearing off what you've already used. Should only take a day. Any roofing supply house should be able to set you up with the proper materials and instructions on their use.
tinner666 is offline   Reply With Quote
Injected too much foam sealer to repair tub, how to remove foam? amodoko Plumbing 4 08-16-2011 01:42 PM
Roofing repair question brokenhammer Roofing/Siding 6 12-08-2009 01:05 PM
House Shingle Repair after Roofing Job bubblegummom Roofing/Siding 7 12-07-2008 02:31 PM
Dishonest roofing companies, or corporate propoganda? KAdams4458 Roofing/Siding 23 11-26-2008 09:33 PM
rolled vs. rubber roofing felix Roofing/Siding 4 03-01-2006 11:16 AM
