Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 03-31-2010, 11:28 AM   #1
Removing tar from PVC stink pipes & metal vents?
All the vent flashing and stink pipe boots have been visited by the "tar monster" ... can i get this stuff off enough to install new rubber boots, or do I need to cut the pipe and join a new section in?
echase is offline   Reply With Quote
Old 03-31-2010, 01:39 PM   #2
Remodeling Contractor
clean with diesel fuel.
Old 03-31-2010, 09:38 PM   #3
Commercial Roofing
AaronB's Avatar
We usually scrape it off.
Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 04-06-2010, 05:27 PM   #4
good tip too wd-40 gets tar off your hands and body really well
chris0914 is offline   Reply With Quote
Old 04-06-2010, 07:20 PM   #5
Residential Roofer
Slyfox's Avatar
Dawn dish soap is safer, WD, oils, gasoline are all bad for your hands, they soak directly into your skin and to your liver. Plus the dish soap won't discolor or damage the roofing materials if you spill some.
God Family Country Work Play
Slyfox is offline   Reply With Quote
Drain Pipes, Walls and Studs mattaparity Plumbing 2 12-18-2011 08:22 AM
Replacing pipes in bathroom, need advice Steelmesh Plumbing 7 11-04-2008 12:30 PM
Removing some vents rdmccaw HVAC 4 10-22-2008 02:00 PM
How to keep attic pipes from freezing in winter with gable vents ErikKratz HVAC 7 07-11-2008 10:32 PM
Removing pipes just to replace a gasket? michael76 Plumbing 5 12-22-2007 11:25 PM
