#1 |
Removing Bedroom Skylight
I have a skylight in our master bedroom that the original owners built in. (See attached photo) To me it's in the most ridiculous location. It's not centered in the room in the firstplace and the skylight is way up in the ceiling rendering it useless. To make matters worse there is evidence of a prior leak and there is some kind of darkening film on it from the outside. A guy at work (who's built homes before told me it would not be that much for a good roofer to come in and take out the skylight and reshingle the roof. The skylight is on the rear of the house so any color differences in shingles would not be seen from the road. I have another friend who does great drywall work and can fill in the opening in the bedroom and paint the entire ceiling. I was told that everything would be around $600..does that seem reasonable for this amount of work?
#2 |
Pro Slate Roofer
That figure could be right. Maybe only $450, to remove the lite, resheath, and patch in, 3-5 hours. Maybe.
Inside, reframe the bottom of the hole, put in a center joist, and sheet it. About $250. Tape and paint, a tad more. I'm looking at it from here, not there though.
Frank To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#3 |
Pro Slate Roofer
If you wanted to light that room up any, get tube lites. Much better for this application. Keep in mind, bedroom skylights can be distracting at night.
#4 | |
Removing Bedroom SkylightQuote:
#5 | |
#6 | |
I'm not sure the roofer needs to do it, and I know I couldn't match that texture. If they could do all that well, and for only $600, I'm guessing they'd be terribly slow. |
#7 |
Pro Slate Roofer
Any roofer should have abasic understanding of simple carpentry and opening that well to the attic, and even framing for the sheetrock shouldn't be a problem.
#8 |
Should, but not too much anymore. Just like most Framers can only frame, they're not really Carpenters like they used to be. Let alone, in some areas, Roofers are not licensed to do Carpentry work.
#9 |
I like to think I have pretty good skills wrt drywall and plaster repairs, and could of course throw a couple nailers in that hole, but always refer the painter for textured ceilings.
#10 |
I am having two skylights in my bedroom and one in the bathroom removed with a new roof put on this year. The remodeling company said it is simple to do. You don't need to completely remove the drywall in the well area. Just make sure holes are punched in them and it's insulated. Mine all leak and I currently have a leak where the wall meets the ceiling below one of them. I hate skylights. Nothing but trouble. Remove it!
#11 | |
#12 |
"crows feet" textured ceiling. They will match the pattern as much as possible and prime and paint the ceiling. Unless you stare at the ceiling and look very carefully, a good company should get it so it is not noticeable. No matter what, no more wall and ceiling stains, repeated "fixes" of the leaks (6 in last few years), and obnoxious rain noise and sun in my face will be awesome!
#13 |
Before pics. The water stains are visible...
#14 | |
| Display Modes | |
| Dome skylight leaking | AAK | Roofing/Siding | 1 | 10-08-2010 06:47 PM |
| Cracked Skylight | rjordan392 | Kitchen & Bath Remodeling | 10 | 05-22-2010 03:30 PM |
| Beautiful Bedroom Renovation! | EdinDesign | Project Showcase | 11 | 10-03-2008 02:40 PM |
| Removing Skylight Screens | jte1130 | General Discussion | 3 | 09-11-2008 11:46 AM |
| your guestimation and or opinion on removing a bedroom | shan | Remodeling | 2 | 12-09-2005 04:46 PM |
