Removing Asphalt Shingles - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-27-2009, 01:02 PM   #1
Rewards Points: 235
Removing asphalt shingles
What is the easiest way to remove roof shingles. 3 layers.
stevez is offline   Reply With Quote
Old 04-27-2009, 01:55 PM   #2
RippySkippy's Avatar
Hire some one else to do it.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 04-27-2009, 02:04 PM   #3
Or a spade/shovel with this type of teeth configuration. Most have a pry wedge on the back...
Or follow this LINK to see some other styles...but the short of it is there is NO easy way....but you can take the sting out by having your dumpster close, cover the ground with tarps....those things help some...
LMASD
Old 04-27-2009, 02:10 PM   #4
Rewards Points: 235
It's only 2 squares so I should get it done in a day...I hope.
Stupid question. Do you rip going up where you get it under the shingles or going down.
Old 04-27-2009, 03:24 PM   #5
2 squares, what'ca wait'n for...get with it!
I usually start working from the top to the bottom taking about 3 courses as I go....BUT you do what works....you may find with that many layers you only remove one or two first then the bottom...you'll just have to feel it out.
The sooner you get finished...the quicker you'll be doi'n this -->
LMASD
Old 04-27-2009, 03:35 PM   #6
Rewards Points: 235
thanks rippy.
GAF Roof... the best EdPDX Roofing/Siding 73 09-12-2011 05:53 AM
Best cement(brand) to seal asphalt shingles to copper valley oldgrunt Roofing/Siding 2 12-07-2008 01:27 PM
CertainTeed Landmark 50 asphalt shingles Wendy Honold Roofing/Siding 113 07-03-2008 11:45 AM
Elastomeric coating for asphalt shingles? Arndavis Roofing/Siding 1 09-04-2007 10:42 PM
asphalt shingles glassman Roofing/Siding 6 10-04-2006 12:03 AM
