Removal Of Rock And Tar Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-25-2006, 01:15 PM   #1
Removal of rock and tar roof
My landloard asked me to re roof his house for him. I have roofed 3 tab before over existing 3 tab. Unfortunatley his house has rock and tar for the roof. How hard is it to remove it and how does someone go about doing it. THX
jimmyaf is offline   Reply With Quote
Old 04-25-2006, 02:44 PM   #2
Contractor
I have done a few and once you get it started it comes off pretty easily.
Protect everything underneathfrom dropping rocks. On my first one, I parked my '68 Chevelle SS 396 a little too close and ended up getting the front clip repainted.
Teetorbilt is offline   Reply With Quote
Old 04-25-2006, 04:48 PM   #3
did you just use a flat shovel?
and just scrape it all to one side??
Old 04-26-2006, 08:10 AM   #4
Commercial Roofing
AaronB's Avatar
Tear off the whole thing, tar, felts, gravel down to the roof deck. I hope you have someone that knows how to flat roof.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 04-26-2006, 09:37 AM   #5
Rewards Points: 150
dont screw around with flat roofing unless you know what your doing, it could be an expensive lesson. if its coal tar pitch then it could also be a painfull lesson.
RooferJim
RooferJim is offline   Reply With Quote
Old 04-26-2006, 11:23 AM   #6
Contractor
Yup, square point shovels. We didn't have any flat roof sections, you have to be careful with them.
Old 04-27-2006, 05:03 PM   #7
Pitched roof
The roof is not flat, it actually has a pitch to it. My fear is the tear off part
Old 04-27-2006, 05:17 PM   #8
Rewards Points: 150
Yes the fun part as well. You dont have to be nuts to be a roofer "but it does help".
RooferJim
www.jbennetteroofing.com
Old 04-27-2006, 06:39 PM   #9
Commercial Roofing
AaronB's Avatar
It is still a low slope system to be installed? What is the pitch?
Old 04-28-2006, 01:09 PM   #10
pitch
2/12 maybe 3/12 at the most, the bids have came in at 4200-5300 for 30 yr shingles
Old 04-28-2006, 03:27 PM   #11
Commercial Roofing
AaronB's Avatar
On that slope, if you can even get it 100% waterproof with shingles, there is no way the shignles will last. The shingle manufacturers will not even warrant the material on that slope. I would suggest going with a low slope roof.
If you do not like the idea of the look of a low slope roof, check this out
http://www.cooleygroup.com/webcont.nsf/0/bldindex
The Illusions line is a low slope membrane that is manufactured to look like an architectural shingle. Perfect for those marginal slopes.
Old 04-28-2006, 03:54 PM   #12
Rewards Points: 150
I would recomend against shingling that low of a pitch,but if they insist then you could apply a layer of Grace I&W then shingle it. It would be foolish to just shingle over paper on that low a pitch.
RooferJim
