Removal Of Gutters For New Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-25-2012, 06:42 AM   #1
Removal of gutters for new roof
Do I have to remove the gutters to put a new roof on?
Greg714 is offline   Reply With Quote
Old 05-25-2012, 06:46 AM   #2
Rewards Points: 13,690
A whole lot easyer if you do, and less change of there getting damaged or stained.
Old 05-25-2012, 07:31 AM   #3
Rewards Points: 83
No you don't have to.
But if you're going to replace your roof and your gutters, leave them on during the roofing tear-off process to catch nails and other small debris. Makes clean up that much easier.
bcdemon is offline   Reply With Quote
Old 05-25-2012, 07:20 PM   #4
RFN-4A-LVN
Roofmaster417's Avatar
Sometimes if the roof is super steep and everything hits the ground it might be a good idea.I have never removed guttering to accommodate a new roof installation.
In Missouri 80% of guttering is attached by gutter posts and spikes.When removing the gutters its difficult to remove the spikes without damaging the fascia and wrap.Then you have to raise or lower the guttering because you would not want to use the same holes to set the spike.
If you raise/lower the gutters then the downspouts have to be reset.Then the entire gutter system has to be set for drainage.It creates more problems than it prevents IMO.
Make sure your roofers are using ladder braces/stand offs.They keep the ladder off the guttering.
Roofmaster417 is offline   Reply With Quote
The Following User Says Thank You to Roofmaster417 For This Useful Post:
Windows on Wash (05-27-2012)
Roof deck removal help paredown Building & Construction 6 05-16-2012 08:22 PM
Gap between roof and gutters. ben4345 Roofing/Siding 4 10-12-2011 05:17 PM
Are you ready for SNOW & ICE ? Roofmaster417 Roofing/Siding 15 10-09-2011 09:25 AM
very difficult house to vent roof help please marlowe Roofing/Siding 7 09-10-2011 11:57 AM
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 12:35 AM
