Reinforcing Rafters - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 01-31-2012, 04:34 PM   #1
Reinforcing rafters
Hello. I want to vault my ceiling in the bedroom and would like to know how to beef up the rafters that will allow me to remove the ceiling joists
Robert1961dob is offline   Reply With Quote
Old 01-31-2012, 05:47 PM   #2
Rewards Points: 2,210
A lot depends on how your rafters are built. Are they 'stick framed' or trusses.
Really need to get someone to look at it and tell you what you can and can not do.
mae-ling is offline   Reply With Quote
Old 01-31-2012, 06:01 PM   #3
Rewards Points: 13,274
Seams like a good idea, but a lot of work, there's got to be something to stop the roof rafter from spreading, all the heat is going to stay traped up near the peak so your going to have to add some ceiling fans to force it back down.
Any time I built a room like this the customer calls back and complains it's now the coldest room in the house.
Old 01-31-2012, 07:18 PM   #4
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Like Joe says, your walls will spread without a ridge beam.
titanoman is offline   Reply With Quote
Old 02-01-2012, 03:07 PM   #5
Depending on the existing structure of the roof system it may be possible, there are ways to keep the walls from spreading. As stated ceiling fans are a good idea.
Old 02-01-2012, 11:20 PM   #6
Disabled wood vet
titanoman's Avatar
Ceiling fans will keep the walls from spreading? Uh-uh.
And yes, perpendicular walls can be sheared or braces let in to counter any tendency to move, as well as the roof itself could be keeping these straight or can possibly be utilized to do so. Depends on the configuration of everything.
Old 02-02-2012, 12:23 AM   #7
Two separate thoughts.
Old 02-02-2012, 12:43 AM   #8
Residential Designer
AndyGump's Avatar
Rewards Points: 662
Send a message via Skype™ to AndyGump
Unfortunately that is just not a question that can be answered here with any kind of authority.
A designer for this would need to know the existing condition of the rafters, ceiling joists, walls, insulation because now you will be looking at doing a non-vented attic, and many other considerations that have to be planned out to work as a whole plan for your house.
Andy.
AndyGump is offline   Reply With Quote
Old 02-02-2012, 08:56 AM   #9
You could do a tray ceiling instead. It would look better than a vault in a BR IMO, not to mention be easier to keep it from coming down like a house of cards.
jmiller is offline   Reply With Quote
Insulating 2x4 attic ceiling rafters help needed tseverson Insulation 2 11-01-2011 08:57 PM
Insulating flat roof with exposed rafters rblevow Insulation 1 05-14-2011 11:00 PM
Doubling up rafters DbKam Building & Construction 2 10-24-2010 10:16 PM
checking the rafters joefromcal Carpentry 3 10-01-2010 09:12 AM
Roof bracing / pulling rafters together JoeT Building & Construction 8 07-08-2010 08:54 PM
