Reglzing A Skylight - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-04-2012, 11:51 PM   #1
reglzing a skylight
what does it cost in calgary to reglaze a 4' x 4' skylight
wallybauman is offline   Reply With Quote
Old 11-04-2012, 11:53 PM   #2
Rewards Points: 13,732
Not going to get much help here on pricing, going to have to make some local calls.
Never heard of a sky light that could be reglazed, what's the real problum?
Old 11-05-2012, 06:32 PM   #3
Metal Roofing
Rewards Points: 600
It is generally cheaper to replace the skylight than to reglaze one. Is this skylight deck mount or curb mount ? Glass or Acrylic ?
It is such a small job there is no $ to be made in reglazing an old skylight. Not to mention reglazing will not come with any warranty...it is still an old skylight it just has a new seal. Chances are if the glazing is bad, it is time to replace the entire unit.
I am mostly refering to curb mount, because that is what i see 90% of the time. Very simple to replace, remove the fasteners, take the lid off, put new lid on...so easy a cave man could do it. (unless it is a steep pitch roof)
Deck mount will require a roofer + a skylight, the new lid will need to be flashed correctly by a roofer.
AndyWRS is offline   Reply With Quote
The Following User Says Thank You to AndyWRS For This Useful Post:
Windows on Wash (11-06-2012)
Old 11-06-2012, 08:07 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,718
Most skylights that are in need of re-glazing could benefit from a complete replacement.
Old 11-07-2012, 03:37 AM   #5
Rewards Points: 2,238
Unfortunately - I've had to re-glaze skylights.
(Flat, glass - not bubble-panes!)
Not worth it!
Curb mount (I hope) -
Replace it, and someone gets to see if they used "Ice & Water Shield" -
correctly!
Also, if the flashing was done correctly!
As stated above - new skylight = new warranty!!
It is a "pain" to re-glaze them!
rossfingal
rossfingal is offline   Reply With Quote
The Following User Says Thank You to rossfingal For This Useful Post:
Windows on Wash (11-07-2012)
Old 11-07-2012, 08:11 AM   #6
JOATMON
ddawg16's Avatar
Rewards Points: 1,826
I agree with replacement as well.....the amount of labor to reglaze vs replace is about the same.
Also....look into tempered glass....it opens up options for better thermal control and you don't have to worry about reglazing a few years down the road.
Greetings from San Clemente Ca: Access Door Install in Skylight Shaft? FINSEEKER Remodeling 1 05-12-2012 05:56 AM
Does skylight need replacing? Ttd0715 Roofing/Siding 17 01-14-2012 03:39 PM
skylight self stick flashing advice Earl0101 Roofing/Siding 2 04-30-2011 09:55 AM
Dome skylight leaking AAK Roofing/Siding 1 10-08-2010 05:47 PM
Cracked Skylight rjordan392 Kitchen & Bath Remodeling 10 05-22-2010 02:30 PM
