Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 01-03-2006, 03:42 PM   #1
Reflective Coating on Flat Roof
Hi Aaron:
I have another question regarding my flat roof. After I have applied this fibered roof coating all over my flat roofs, should I apply that aluminum coating to deflect the sun off the roof, to keep the roof cooler? Or should I use white coating? How long should I let the fibered roof coating cure before I apply the reflective roof coatings? Any other suggestions about this? Aaron, I am the woman who posted before about my flat roof and replacing shingles (after Hurricane Wilma), a few weeks ago. Thank you for your help.
Melinda
MelindaA is offline   Reply With Quote
Old 01-03-2006, 09:43 PM   #2
Commercial Roofing
AaronB's Avatar
Hi, Melinda.
I would use white for optimal reflectivity and let whatever is is youre putting on there cure for a t least 90 days...maybe longer if the migratory oils have not fully migrated.
For the record, I do not recommend the fibered roof coating, but you already know that.
Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 01-04-2006, 11:53 PM   #3
No, I didn't know that you don't like fibered roof coating. Tell me why, please, as I am not finished applying and may switch over to something else, if you will recommend something else to me. Thank you.
Melinda :o
Old 01-05-2006, 06:08 AM   #4
Commercial Roofing
AaronB's Avatar
I doesnt serve any real purpose...except to get money from you and send it to them.
what type of coating for flat roof kenny357 Roofing 5 06-25-2007 05:47 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing 4 11-19-2006 07:17 AM
flat roof leak snikda9 Roofing 16 01-26-2006 05:25 PM
Need Help on the Flat Roof and more... MelindaA Roofing 12 12-21-2005 11:12 PM
Where flat roof meets shingled roof bstyer Roofing 1 07-07-2005 09:34 PM
