Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing/Siding
Old 03-16-2012, 11:08 AM   #1
Question
Redoing a roof
I have a three season cottage and I need to redo my cathedral ceiling to add a vapour barrier in. We had ice build up over the winter as we heated with a newly installed wood stove.
Roof shingles need to be replaced this spring so my taught was to add 2' by 4's on the existing roof and cover with plywood then reshingle. Vents will need to be added as well to create proper airflow.
Am I on the right track?
I'm looking for the most effective way of doing this.
Look forward to any comments.
cottageowner is offline   Reply With Quote
Old 03-16-2012, 11:26 AM   #2
Redoing a roof
Having a hard time try to figure out the logic of doing it that way.
Google EPS and check this method out instead.
http://www.achfoam.com/NailbaseRoofInsulation.aspx
It's foam panels with OSB attached to the insulation that goes over the sheathing that's on the roof now.
You would have to remove the shingles you have now.
Old 03-16-2012, 11:56 AM   #3
Redoing a roof
Hmmmm.... I guess it doesn't hurt to have more insulation. The roof is already insulated from the inside. I need to keep cold air circulating (air barrier) to prevent ice build up and also looking for a cost effective solution.
Definitely food for thought.
Thanks for your reply.
Old 03-16-2012, 12:06 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Redoing a roof
You should check and see what the attic/ceiling thermal insulation requirement is for your region before you start adding additional insulation - to ensure that you are not overkilling what you have.
Also, check and make sure that your existing rafters or trussess, can handle additional roof material load (weight) + snow loads.
- Build Well -
Old 03-16-2012, 12:52 PM   #5
Redoing a roof
Very good point!
help! strange horizontal bubbles on new roof dfwnewroof Roofing/Siding 49 11-17-2012 07:46 AM
Tell me about roof coatings for an older roof Leica Roofing/Siding 3 09-19-2010 02:55 PM
Flat roof and insulation quandry paredown Roofing/Siding 2 08-21-2010 12:50 AM
Tying new roof into old. Clutchcargo Roofing/Siding 15 11-07-2009 06:48 PM
Please help with the design of this roof jaymay75 Building & Construction 1 05-06-2008 10:44 AM
