Redgard On Shed Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 02-24-2014, 10:27 AM   #1
Rewards Points: 99
Redgard on Shed roof
Hello to all and thanks in advance!!
The last couple of weekends my wife and I have embarked on the task of building a shed. So far so good but I have a question on with the waterproofing the roof. Last year I used redgard on the shower as a moister barrier and had a bunch left over. Without much thought, I applied the redgard no the roof of the shed but have not had the opportunity to put shingles on as of yet. Does not rain much out here, should the regard alone suffice? or should I grap some the proper waterproofing material? seems like it should do the job?? Thanks again!
er78mph is online now   Reply With Quote
Old 02-24-2014, 01:22 PM   #2
Rewards Points: 12,886
Are you joking? If not that's completely wrong.
It needs 30 lb. tar paper.
Need to install the shingles ASAP after the shingles go on. Same day would be best.
Old 02-24-2014, 03:18 PM   #3
Rewards Points: 256
Its just a shed. There is nothing wrong with thinking a little out of the box. The sun will dry out the redgard though. So you should put down shingles. If you are feeling a little lazy you can go with roll roofing basicly shingles in a 3'x36' roll.
JustinK is offline   Reply With Quote
Old 02-24-2014, 03:46 PM   #4
Do that and be back roofing again in a couple of years.
I would not use roll roofing on a dog house.
OldNBroken (02-24-2014)
Old 02-24-2014, 04:24 PM   #5
Doing This Way Too Long
Rewards Points: 532
Well this is a first. Mighty expensive waterproofing for a roof. lol.
It being on there is no big deal but if you don't want to roof it yet I would at least get some ice/water shield and put it down. It doesn't sound very big since you coated it with RedGard so should be a good fix for now.
Rolled roofing should NEVER be offered as a solution to ANYTHING. Pretty sure that's the opinion of most on this forum. (at least I hope it is)
Roofing 101 - Think Like Water
OldNBroken is offline   Reply With Quote
The Following User Says Thank You to OldNBroken For This Useful Post:
joecaption (02-24-2014)
Old 02-24-2014, 04:40 PM   #6
Shed Roof
I know a number of certified roofers who have been in the business for a long time, and they say if you absolutely have to, you can wait a few weeks with the tar paper on before shingling. If you are in a bind for time or the weather doesn't permit, you CAN wait but of course, it is always best to go ahead with the roofing. Tar paper is rated for 30 days of use, read it on the package. Not saying just leave it for the 30 days, but the manufacturer says you can if you get in a bind.
I personally don't use rolled roofing myself, but my father-in-law used it on many occasions and his work never leaked. And I am talking a long time ago it was installed. Again, I don't use the stuff myself, but some people just HAVE TO GO THE Cheapest route they can, and so they are limited. I know of several houses in an old neighborhood that used the rolled roofing. I don't see their roofs caving in. I don't use it myself but I wouldn't judge someone who did.
TedLeger is offline   Reply With Quote
Old 11-03-2015, 04:23 PM   #7
Rewards Points: 2
I used redgard on a shed's roof about 8 years ago. I did three layers of redgard and followed with 2 coats of exterior paint, never has leaked. I painted it so the sun would not deteriorate the membrane.
germ29 is offline   Reply With Quote
The Following User Says Thank You to germ29 For This Useful Post:
roofermann (11-04-2015)
Old 11-03-2015, 06:20 PM   #8
Rewards Points: 2,630
I suppose if you live on a farm, anything goes. But otherwise that is going to rate as a pretty darn ugly roof. I would put paper and shingles on it just so that I was not embarrassed when friends came over.
SPS-1 is offline   Reply With Quote
The Following User Says Thank You to SPS-1 For This Useful Post:
joecaption (11-03-2015)
Old 11-03-2015, 06:43 PM   #9
All that work and materials doing it the wrong way!
I papered and shingled my whole 24 X 24 garage by myself in one day.
Adding a lean to roof to shed Mills314 Building & Construction 5 10-14-2013 10:57 AM
Ceiling joists with shed style roof? agent008 Building & Construction 3 09-29-2013 02:30 PM
add shed roof to gable roof lucy1 Roofing/Siding 0 10-30-2011 09:31 PM
Shed roof addition & insulation qustion radgumbo Roofing/Siding 2 12-06-2010 06:33 AM
Shed Porch roof tying in... my5sons Roofing/Siding 7 10-27-2009 09:19 PM
