#16 | |
Recommendations for roof type when reroofQuote:
Granted I suppose one can question whether the manufacturer will abide by that installation procedure they list in the document, or if they'll try to wiggle out of the warranty guarantee when you file a claim. Just wanted more insight on that. |
#17 |
Yes, I am considering that option as well. For case of metal, what's good? Standing seam vs metal shingles?
I had interest in that a while back and consulted 2 roofers about it when they assessed my roof for a bid. One didn't offer metal roofing. The other did and gave a bid quote that included metal options: I was quoted around $12k for highest grade asphalt shingles, $15k for metal shingles, and $27.5k for standing seem metal roof. Not sure about the other low slope roofing options, will have to check with my local roofers, but for metal at least, I think I'll have less selection of roofers to go by. Seems in northern California, for residential roofing, asphalt shingle is most popular. I have seen homes in my area with asphalt shingles, architectural shingles, wood shake, tile, and tar & gravel. With shingles being most dominant. I don't think I've seen the other low slope roofing options or metal roofing on residential homes unless they look so much like shingle or tar & gravel. So I might have harder time finding roofers who do those roofs. Last edited by daluu; 12-06-2012 at 09:03 PM. Reason: clarifications |
#18 |
why would you hear rain more on a metal roofed house. Proper insulation and laying the metal on top of the current roof will cut out all excess noise. and in most cases the roof will last longer then shingles or torch down
#19 |
Metal Roofing
Metal shingles also have a slope requirement, you would not typically do metal shingle on 2/12. I would go standing seam on the low slope and metal shingle on the 4/12. If you want it matching, i think your looking at SS on the whole thing. I am not aware of a low slope metal shingle.
A "metal shingle" usually refers to a certain type of metal roofing that simulates composition type materials. A "metal shake" is a wood shake look a like. A"metal tile" is a concrete tile look. Lower in profile to the spanish tile look. There are also some metal roofs that simulate the clay S tile look, like Dura Loc Continental, Metro Roman, Decra Villa ect... If you need a metal roofer your in a good location. You have access to a lot of experienced metal folks. Back in the very early 80's, metal roofing exploded in your area, it was introduced in 78 to 79 in Sacramento so i am sure they branched out to your location by 80-81. A lot of those folks are still working in your neck of the woods. At one time or another they probably all worked for Cal Pac Roofing, who was the driving force for metal back then. You had two choices then, Decra or Gerard...now you have probably more than 40 choices. |
#20 |
Roofmaster
Same Thing
#21 |
Roofmaster
You can use metal roofing as long as you use an architectural standing seam metal roof with sealant in the ribs, and you use something like EPDM in the valleys below the metal or high temperature ice dams flashing as secondary protection. with all the valleys you have you are talking $1200.00 bucks a square or so.
You can use Mod bit all over, but it is does not look very good, unless you flood coat and gravel it, then it looks pretty good with white chip surfacing. use SBS mopped in special steep asphalt (Type 4) in two plys over a nailed G2 Base sheet . Use a torch down APP if you want to burn your house down The mod bit is probably your best bet for a leak free long lasting roof. There are a lot of options, it all depends on how deep your pockets are. I would not mix roof types in any case. |
#22 | ||
Exterior Construction
If you use the right lock type, you can run it in 0:12 applications. Quote:
Decra's mins are usually 3/4:12 even with the newer systems.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#23 |
Roofmaster
You can do anything you want, it does not mean that it wont leak though. Anyone that runs a metal roof dead level is a fool.
#24 | |
Low Slope Roofing
For example like us, we will offer a 10 year on most residential flat roofs or we will offer a inspection program for $XXX.XX a year, as long as the home owner keeps up on the inspection each year the roof will be warrantied for that year, up to XX years. I find this is better because then you have someone look at your roof ever year and you can keep "track" of it. It also includes minor touch up as needed. Either way you pay for the "warranty" another good thing about this is say on a epdm roof, 5-15 year roof on a 60 mil is all the same details and such. Another option that works really well on your house is a hot mopped asphalt roof as mentioned before but instead of a smooth cap sheet put on a granulated cap sheet. It's not quite as good as a smooth cap and rock but it looks nice if done right, or you could alway up marble chips instead of lime stone, this looks nice but is expensive. |
#25 |
Roofmaster
I think that there are a lot of you guys out there that are under a drastic misconception about metal roof systems and warranties. I was a Butler weathertite gold inspector, and at that time they (Butler) was the only metal roofing manufacturer that had a leak free FULL SYSTEM warranty.
The other manufacturers warranted against leaks through the panels. (Not the ribs, or flashings or other accessories.) THROUGH THE METAL PANELS. BIG DEAL Honest, Im not kidding. READ THE WARRANTY They did this because they did not have control of every aspect of the installation like Butler did. Many parts were third party, like screws, sealant etc. Butler actually had little tiny balls in their sealant to prevent it from being squeezed out of a lapped seam. Their installers had to go through an extensive intensive installation course. (Same one I went through) Very impressive. Thats why they cost more |
| Display Modes | |
| Leaking outdoor faucet (help identifying type) | shardy | Plumbing | 5 | 06-09-2012 10:35 PM |
| What type of cat5e cable type fastener? | Ranger31 | Electrical | 8 | 06-29-2011 10:01 AM |
| Filler recommendations for wood floor | phavel | Flooring | 1 | 04-10-2011 09:47 PM |
| Masonite type stucco siding | Cmeller | Carpentry | 3 | 03-28-2011 11:15 PM |
| Type L Or M Copper Pipe | bobo | Plumbing | 1 | 11-20-2005 08:53 PM |
