Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing/Siding
Old 12-04-2012, 01:52 AM   #1
Recommendations for roof type when reroof
I have a roof with both 4:12 and 2:12 slopes. In other earlier posts, folks have suggested I look into other roof types meant for low sloped roofs.
But what should the overall roof system be includng the 4:12 slope? One single roof system meant for low slope used for the higher slope too?
Or have a mix of normal and low slope roofing types and integrate/join appropriately at the valleys?
The current roof is all asphalt shingle across slopes.
Attached is a photo of my roof from Google maps overhead view. I've marked the slopes of the roofs. Area A is a valley where the valley is very close to plumbing vent pipes. On reroof either need to move vent pipes further out or make custom valley to properly seal the vent flashings with the valley flashing. Attic there is small, so moving pipes will have to do from the roof top after old roof torn off. Area B is a hog valley where 4:12 pitch roofs meet a 2:12 roof.
I can post addiitonal photos from side or down below view if needed.
So seeing the photo(s), what kind of roofing do you recomment? In terms of whole roof or what on which slope roof (if a mix).
daluu is offline   Reply With Quote
Old 12-04-2012, 12:40 PM   #2
Low Slope Roofing
You could mix them up, 4:12 shingles 2:12's being another product or you can put the same product on the 4:12's as 2:12's.
Any single ply membrane EPDM,PVC,TPO would be fine, a Self adhered modified or a torch down would be fine too, A hot asphalt would work but on a 4:12 the roofer would need to know what he is doing.
Actually on the whole thing the roofer better know what he is doing, the valleys would be an increased concern when using two different types of materials.
1985gt is offline   Reply With Quote
Old 12-04-2012, 02:09 PM   #3
Grumpy's Avatar
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
You could mix up the roof like GT said or just cover the entire roof with a low slope membrane. There are a few membranes with printed shingle patterns. But first thing first, shoot the Architect in the face! It should be a requirement that these guys work in the trades before they can start designing chit.
Personally speaking if I were to mix it up, I would be recommending a granulated torch applied modified bitumen in the 2/12 areas and a good quality fiberglass/asphalt shingle in the steep slope areas. http://reliableamerican.us/articles/...a-shingle.html Having said that, if I had my way I may actually propose one of the shingle patterns PVC membranes and simplify the entire project.
-Grumpy
Sometimes the savings that comes from doing it yourself can be blown away with one mistake.
The information found in this post is not to be considered legal advice. All information should be considered relative, not specific. Never attempt any repairs you are not comfortable with. Always maintain safety! The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Old 12-04-2012, 02:36 PM   #4
Low Slope Roofing
I agree with grumpy. If it was mine I would do a low slope membrane over the whole thing or a granulated mop down, *IF* I was doing it my self, I don't know I if I would trust others doing a mop down on this design. Possibly with a shingle PVC or even a TPO or PVC with standing seam "battens" welded on. The PVC with the battens will be very expensive but it actually looks very nice.
Old 12-04-2012, 05:58 PM   #5
1985gt, can you provide some photo references for shingle PVC and PVC with battens? Would like to know what they look like. Also for shingle PVC, do those flake off granules like asphalt shingles do over time?
Old 12-04-2012, 06:02 PM   #6
FYI, the mod bit was proposed by one roofer, but only at the hog valley (area B) with rest using asphalt shingles. But that was also because in all my reroof inquiries, when asked what kind of replacement roof, I just said shingles. Though I assume a really good roofer may suggest alternatives like you guys do, but I haven't met one roofer (in my area) who actually did suggest those. Not sure why...(price? inexperience? popularity of shingles in my area so they specialize/focus on that?)
Old 12-04-2012, 06:34 PM   #7
Low Slope Roofing
Look at GAFs web site for the batten style roofs. Ill have to do some digging for the shingle print its been awhile since i seen them. Mod bit would be a good option for the total roof. The valleys on that woupd be one of the best. Ill do some looking tomorrow when im in the office.
Old 12-04-2012, 07:25 PM   #8
Metal Roofing
I like the modbit for the low slope and shingles for the 4/12 idea.
The low slope single ply on the whole thing would work also which has been mentioned. I would be concerned about the installation contractor first, you want someone who knows what they are doing no matter what direction you choose.
AndyWRS is offline   Reply With Quote
Old 12-04-2012, 08:52 PM   #9
How might a homeowner inexperienced with roofing best figure out qualifications of a contractor? Checking their license status and any BBB complaints is a start, but figure that's not enough.
Old 12-05-2012, 11:25 AM   #10
Grumpy's Avatar
http://www.traditionsclassics.com/ Look at the IB traditions. You have to be a certified installer to even buy the stuff.
Here is a link on hiring your contractor: http://www.reliableamerican.us/artic...contractor.htm
Search their reputation online. The BB is a good source to see if they have complaints, don't bother with their silly rating system. If they have alot of complaints, it's a gamble. Also simply google their company name and see what comes up. Perhaps google "rofoers name problems" or "roofers name complaint" see what comes up. Heck google the estimator by name as well. See if he is bragging about his more recent con on his facebook page, or maybe shooting up heroien on his twitter account.
See some of his finished work. Talk to home/property owners.
-Grumpy
Old 12-05-2012, 12:43 PM   #11
Low Slope Roofing
http://www.gaf.com/Roofing/Commercia...PO_Accessories
Link to the GAF website the standing seam profile is about 1/2 down the page.
Talk to the contractors customers, once you have a couple narrowed down ask them for references. If they are unwilling to provide any, then simply move along, ask to check out other project similar to yours you can actually go see. The BBB is not really a reliable source, people can pay for a better rating and anyone can make a complaint against a contractor. On site visits and references is where it's at.
Old 12-05-2012, 03:04 PM   #12
Exterior Construction
Windows on Wash's Avatar
+1
Have you considered metal?
Old 12-06-2012, 11:58 AM   #13
Roofmaster
Steep (water shedding roofs) stop at 3/12. Anything under 3/12 is considered low slope.
HOWEVER. I have seen a lot of shingle roofs installed at 2/12 successfully but you need to do the following:
Install ice dams flashing over the entire roof, and double it in the valleys 6 feet out in both directions. make all laps 6 inches and roll in.
Move vent pipes up out of the valleys, That is just plain dumb.
Only use 3 tab shingles, not architectural, as they present less resistance to wind blown rain.
cut the exposure down to 4 inches not 5. Hand nail.
Use gable end vents not ridge vents
Your roof wont leak.
SIngle ply, metal or batten types can be used if you are rich, but all of these bring other things into play. You will really hear rain hitting metal, and snow slides off and crushes stuff. PVC and TPO will look like crap in short order because it builds up static electricity and attracts dirt. Snow will slide off these too, crushing things.
The other options will also cost a lot more than shingles.
Old 12-06-2012, 01:21 PM   #14
Low Slope Roofing
Ice and water shield the whole roof and dropping the exposure rate on the shingles adds a significant cost to the roof. Putting it up there with a reliable low slope system.
Reasons not to install shingles: Voids warranty, product not ment for low slopes, will wear out 2X or more faster on low slope roofs.
The Following User Says Thank You to 1985gt For This Useful Post:
JWilliams850 (12-06-2012)
Old 12-06-2012, 08:43 PM   #15
Thanks jagans for a different opinion on the matter.
What is ice dams flashing? Is that separate/different from ice & water shield barrier or same thing?
Current roof is using 3 tab shingle instead of architectural I believe. It also has gable end vents (on the 4:12 slope) and not ridge vents, the low slopes are open beam ceilings below, no attic, so no venting on those (apparently no soffit vents either, don't know if they're needed for that or not). The 4:12 slopes also have eyebrow vents in addition to the gable vents.
Leaking outdoor faucet (help identifying type) shardy Plumbing 5 06-09-2012 10:35 PM
What type of cat5e cable type fastener? Ranger31 Electrical 8 06-29-2011 10:01 AM
Filler recommendations for wood floor phavel Flooring 1 04-10-2011 09:47 PM
Masonite type stucco siding Cmeller Carpentry 3 03-28-2011 11:15 PM
Type L Or M Copper Pipe bobo Plumbing 1 11-20-2005 08:53 PM
